brake backing plate swap #1473089
07/24/13 12:05 AM
07/24/13 12:05 AM
minnesota
P
president61 Offline OP
P
minnesota
will backing plates and hubs from an a body 8-1/4 fit a a body 8-3/4?
Re: brake backing plate swap [Re: president61] #1473090
07/24/13 12:14 AM
07/24/13 12:14 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yes..
I am truckless..
Re: brake backing plate swap [Re: president61] #1473091
07/24/13 01:38 AM
07/24/13 01:38 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
A body 8-1/4 is large bolt pattern, 8-3/4 is small bolt pattern.
Are you changing axles?
Re: brake backing plate swap [Re: nomore65BelvJim] #1473092
07/24/13 01:40 AM
07/24/13 01:40 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Oops my bad eye read b body 8 3/4.. but the backing plates will still bolt on..
I am truckless..
Re: brake backing plate swap [Re: nomore65BelvJim] #1473093
07/25/13 12:04 PM
07/25/13 12:04 PM
minnesota
P
P
minnesota
yes i am. good observation
Re: brake backing plate swap [Re: president61] #1473094
07/25/13 12:49 PM
07/25/13 12:49 PM
If your going with aftermarket axles NOT set up for the A body brake offset you can use about any 65-up non-A body mopar rear brakes.
