Cracking Rear Brake Shoes #147254
11/08/08 12:37 PM
11/08/08 12:37 PM
SW Fla.
CYACOP Online content OP
CYACOP  Online Content OP
SW Fla.
71 Road Runner
Shoes replaced a couple of years ago, bought from local parts house. Maybe 4,000 miles since installed.
Rear brakes start getting a metallic sound when rolling slowly.
Cracks formed on shoe face.
Fresh metal evident on outside of drum surface.
Any help?
Re: Cracking Rear Brake Shoes [Re: CYACOP] #147255
11/08/08 12:37 PM
11/08/08 12:37 PM
SW Fla.
SW Fla.
Re: Cracking Rear Brake Shoes [Re: CYACOP] #147256
11/08/08 12:48 PM
11/08/08 12:48 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Cracks in shoes face are normal. Not uncommon to see when I check brakes. However I would look at the side of the shoe though for fresh metal.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Cracking Rear Brake Shoes [Re: HealthServices] #147257
11/08/08 01:37 PM
11/08/08 01:37 PM
SW Fla.
SW Fla.
Well, I chamfered the outer edge of the shoes and reinstalled. The squeaking is gone. Not sure why that was happening though.
Re: Cracking Rear Brake Shoes [Re: CYACOP] #147258
11/08/08 01:58 PM
11/08/08 01:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Cracks in the shoes usually come from getting the shoes too hot with hard braking. It makes the lining hard and chrystalized. This decreases the stopping ability. You should sand the face on the linings to get rid of the hard surface for better braking and sand the drums for the same reason.
Re: Cracking Rear Brake Shoes [Re: CYACOP] #147259
11/08/08 02:42 PM
11/08/08 02:42 PM
GMP440 Offline
GMP440  Offline
Those cracks are normal. I've never had a set of brake shoes that did't have carcks after a bunch of miles use.
Re: Cracking Rear Brake Shoes [Re: GMP440] #147260
11/08/08 04:09 PM
11/08/08 04:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have had very few shoes crack. I have replaced a large number of brake shoes on customers cars that weren't cracked. Cracked shoes usually come from cars with discolored drums which is another sign of hot brakes. It tells me your doing a bit of hard braking or your drums have been cut thin and can't disapate heat fast enough.
Re: Cracking Rear Brake Shoes [Re: stumpy] #147261
11/08/08 04:16 PM
11/08/08 04:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I have had very few shoes crack. I have replaced a large nimber of brake shoes on customers cars that weren't cracked. Cracked shoes usually come from cars with discolored drums which is another sign of hot brakes. It tells me your doing a bit of hard braking or your drums have been cut thin and can't disapate heat fast enough.
Not normal, overheating brakes....
Re: Cracking Rear Brake Shoes [Re: CYACOP] #147262
11/08/08 05:25 PM
11/08/08 05:25 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
put on some quality carbon metallic shoes so you can stop, good brake linings do not crack
Rochester clutch and brake
585-232-3717
Re: Cracking Rear Brake Shoes [Re: ThermoQuad] #147263
11/08/08 06:42 PM
11/08/08 06:42 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Since they are on the rear, let's bring up the "burnout" or Brake Torquing as another reason there was a ton of heat.
Also possible was the shoes were too tight against the drum and were dragging creating the heat.
Another common problem with rear shoes is the parking brake being adjusted too tight or rusted and sticking holding pressure on the shoes all the time..
If it were my car I would immediate replace them, I have seen a few shoes like these fracture and chunks lock up the wheel.
Re: Cracking Rear Brake Shoes [Re: sthemi] #147264
11/08/08 08:43 PM
11/08/08 08:43 PM
ont, canada
K
kenny b Offline
kenny b  Offline
K
ont, canada
Simple answer. All bonded shoes crack over time and usage from heat. Quality riveted shoes equals problem solved.
Kenny B
Re: Cracking Rear Brake Shoes [Re: kenny b] #147265
11/08/08 09:56 PM
11/08/08 09:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Simple answer. All bonded shoes crack over time and usage from heat. Quality riveted shoes equals problem solved"
That isn't true, I have done better than 1000 brake jobs over the years and bonded shoes don't all crack. Cracking is caused when the shoes become hard from being over heated. That isn't a normal situation. Normally shoe material stays flexable if not over heated and won't crack. Riveted shoes do the same when they get too hot. You're an auto shop teacher and should know that.
Re: Cracking Rear Brake Shoes [Re: stumpy] #147266
11/08/08 10:24 PM
11/08/08 10:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There are those that do...& Those that teach...
Re: Cracking Rear Brake Shoes [Re: 1_WILD_RT] #147267
11/08/08 11:27 PM
11/08/08 11:27 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I can report cracked linings due to overheating of rear brakes.
The evidence is pretty clear because I am struggling with uneven brake pressure on the rears and I can tell you this: The side with the brake that is doing all the work is cracking (and squeaking).
The other side with less pressure is just fine.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Cracking Rear Brake Shoes [Re: 67SATisfaction] #147268
11/09/08 03:53 AM
11/09/08 03:53 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Re: Cracking Rear Brake Shoes [Re: DennisH ] #147269
11/09/08 08:55 AM
11/09/08 08:55 AM
SW Fla.
SW Fla.
Thanks for the input and information on this. It may be possible that the drums are thin. I dont know but that can easily be checked. I dont know the history there. I think I will verify that and if needed replace the drums and go with a quality shoe and keep an eye on it. There wasnt any blueing on the drums and I dont power brake for burnouts, so I cannot contribute to abuse but those are good points.
Thanks again for the help.
Re: Cracking Rear Brake Shoes [Re: CYACOP] #147270
11/09/08 11:46 AM
11/09/08 11:46 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Any brake shop will measure the drums for you and on the face of the drum near the edge should be a max diameter listed.
Re: Cracking Rear Brake Shoes [Re: DennisH ] #147271
11/09/08 01:36 PM
11/09/08 01:36 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
www.praisedynobrake.com
Has anyone used this product??????????
Re: Cracking Rear Brake Shoes [Re: kenny b] #147272
11/09/08 05:56 PM
11/09/08 05:56 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
I agree with Kenny that the bonded shoes are the problem. I see it all the time on my customers cars with bonded shoes, but almost never with rivited shoes. Even daily driver cars with bonded shoes are almost always cracked.
Re: Cracking Rear Brake Shoes [Re: mrrandyj] #147273
11/09/08 08:55 PM
11/09/08 08:55 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
I have some rivited with cracks!
