Re: Replacement fan clutch
[Re: magnum440d100]
#1472343
07/22/13 10:26 PM
07/22/13 10:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If your original unit happens to have the part number on it, it could be cross referenced. RockAuto is pretty good at listing the OEM numbers as a cross.
[Re: Supercuda]
#1472344
07/23/13 06:45 AM
07/23/13 06:45 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Just ordered a HAYDEN 2706 for a buddy, if you like I can let you know how it fits when it comes in this week.
[Re: mnguy55]
#1472345
07/23/13 01:07 PM
07/23/13 01:07 PM
Posts: 5,439 So Cal
Sinitro
So Cal
The original (I think) fan clutch in my 70 Charger R/T 440 w A/C just seized up and started to howl like mad. The car is stock and I'm just looking for as close as possible parts store replacement but when I look at Napa and Oreily they have a ton of different ones that supposedly fit. Can anyone recommend a specific one from either store that will functionally be about the equivalent to the stock original one.
Major issue is its height... Check the original OE closely.. Put it face down and measure. Also most replacements are universal and have slotted mounting holes for mounting to the water pump.. Whereas the OE had 4 holes.
Just my $0.02...
[Re: 1fastrunner]
#1472347
07/24/13 12:13 PM
07/24/13 12:13 PM
Posts: 5,439 So Cal
Sinitro
So Cal
I was told Parts Master 1705, have yet to get it to check out. Jim
You have to check it for the mentioned points. Again height is crucial as to get proper radiator/shroud clearance, plus one is able to change out the fan belt without a hassle..
Just my $0.02..
