2012 Caravan noise under driver side dash? #1472336
07/22/13 08:57 PM
07/22/13 08:57 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hi Guys, we just bought a 2012 Grand Caravan Crew. We love the van, especially the 3.6 VVT. It is a blast to drive. The problem we are having is a little clicking noise under the driver side dash. It sounds like plastic rubbing together, it is driving us nuts! I cant find it! Have any of you had this problem and figured it out? Any help would be greatly appreciated.
Thanks Again Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: 2012 Caravan noise under driver side dash? [Re: ScottG] #1472337
07/23/13 02:18 AM
07/23/13 02:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Does it do it with the blower motor running?Ive seen a lot with something in the cage.Had a few that would barely run because of junk in there.Either that or it might be an acutator for the heater assembley.Most are gears and plastoc and they can strip.Rocky
Chrysler Firepower
Re: 2012 Caravan noise under driver side dash? [Re: therocks] #1472338
07/23/13 06:21 AM
07/23/13 06:21 AM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
No, it does it with everything off too. It is worse when hitting little bumps. I just can not tell were it is coming from.
Re: 2012 Caravan noise under driver side dash? [Re: ScottG] #1472339
07/23/13 08:17 AM
07/23/13 08:17 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Is there something stuck in the cowl area under the hood? I had a small rock in ours and it sounded like it was inside the dash.
Re: 2012 Caravan noise under driver side dash? [Re: MI_Custumz] #1472340
07/23/13 08:04 PM
07/23/13 08:04 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Well I think we found it. The runners under the drivers seat. I put a little grease on them and ran them back and forth. We cant hear the noise anymore. I hope that was it. Thanks for your help.
Scott
P.S. Test drove it tonight. No noise, it was the seat runners!
