Re: 03 dakota 6 to 5 lug conversion?
[Re: 65rbdodge]
#1472252
07/22/13 07:08 PM
07/22/13 07:08 PM
dogdays
Not that easy. It's been suggested to buy aftermarket hubs, plug weld the holes except one, and redrill to the 5 lug pattern. Then you redrill the rotor too. Using an earlier rotor is out as they are both smaller diameter and thinner.
R.
[Re: dogdays]
#1472256
07/24/13 11:59 PM
07/24/13 11:59 PM
Posts: 13 NB, Canada
Mirada 80
NB, Canada
So just wondering, can the early spindles that take the rotor be changed out with the later spindles that take the hub? The later upper control arms have bolt in ball joints, which are far easier to replace.
Keep your Mopar all Mopar
