Super Stock Springs.
#1472077
07/22/13 10:44 AM
07/22/13 10:44 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
About to order a set of Super Stocks for the Bee. Need some recommendations. Would it be better to get the 3600 or 3800 pound springs? I'm guessing it will be closer to 3800 lbs, but maybe the lighter ones would give me a reason to lighten!? Also, I'm aware of the difference between the right and left spring. Any advantage to running two right springs other than making the car sit level(I know I can adjust the torsion bars to level it, but 6 leaves to 8 leaves...)? Thanks in advance FYI, 4-speed street car that will see weekly track duty.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Super Stock Springs.
[Re: OhioMopar]
#1472078
07/22/13 11:10 AM
07/22/13 11:10 AM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
Go with the correct ones and forget the cosmetics. If the car is right, it won't sit level....they are designed with different leaves on the right and left for a reason.
SS springs work great....been using them for 40 years, we do mess with clamps and stuff like that to tune them. But, forget the idea of using two right ones for cosmetic purposes.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Diplomat440]
#1472080
07/22/13 12:09 PM
07/22/13 12:09 PM
OhioMopar
Mt.Gilead, Ohio
Thanks to both of you. I will check them out when I get them.
[Re: 67Satty]
#1472083
07/22/13 01:04 PM
07/22/13 01:04 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I always make my own bushings out of aluminum front & back,works better than the rubber bushings an the holes are centered!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: OhioMopar]
#1472085
07/22/13 01:43 PM
07/22/13 01:43 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
One, get your car weighed and stop goofing.
Two, don't ever buy another set of SS springs, they are junk. Go right to Calvert racing and get a set of split Mono's...Those will be better than anything you get that states its an SS spring..Add Caltrac's when you can.
Then re-adjust your front torsion bars because they will be all out of whack making up for the SS springs you just took off.
