Re: Best carb soaking solution
[Re: 426runner]
#1472070
07/22/13 10:35 AM
07/22/13 10:35 AM
RapidRobert
If it's an Eddy you could soak the small internal parts seperately by themselves & with the carb upright pour some soup into the carb bowl to clean the internal passages so the outside stays pristine. There's no metering in the top so you could clean it with something that's non toxic to the finish/same with the outside linkage. this also lets you get by with purchasing a smaller amount of cleaner as you dont need a big enough bucket for the whole carb to fit into
[Re: Challenger 1]
#1472072
07/22/13 12:56 PM
07/22/13 12:56 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I use this stuff, it's only 50 bucks a gallon. Works great and I have done 2 carbs and 3 spray guns with it now.
I really like the "ONLY" part of you recommendation !!
[Re: 62maxwgn]
#1472074
07/22/13 01:48 PM
07/22/13 01:48 PM
Challenger 1
Cincinnati, Ohio
He asked for the best and IMO this is the best.
