Dead-hooking FINALLY... #1471967
07/22/13 01:58 AM
07/22/13 01:58 AM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
Threw the 29 x 10 Hoosier bias's out...put on some 30 x 9 D05 Hoosiers @ 14# cold...Caltracs bottom hole no preload...shocks on 6 (Rancho 9 ways)...3700# Pink Pig cranks a 147.1, 147.3 and a 147.5 60 foots today. Usually a good 60 was 1.52 or so. Normal ET of 6.96 or so dropped to 6.84 in the 1/8th. And at an Airport drag strip to boot....
Man it's been a long road but I think I finally got something right!!
Now to play with the settings on the rear a bit.... I'm curious now!!!
Re: Dead-hooking FINALLY... [Re: superwrench] #1471968
07/22/13 06:37 AM
07/22/13 06:37 AM
michigan woods
imfixinmopars426 Offline
michigan woods
good for you! its fun when you make progress on 60ft times! you did something right,just write it down so you will remember,lol
Re: Dead-hooking FINALLY... [Re: superwrench] #1471969
07/22/13 08:49 AM
07/22/13 08:49 AM
gregsdart Offline
gregsdart  Offline
Great job.
Re: Dead-hooking FINALLY... [Re: gregsdart] #1471970
07/22/13 12:10 PM
07/22/13 12:10 PM
Thanks...yeh...I'm still a little mystified that the narrower tires hook like they do. Although they are soft compound. People used to ask me why I run 14 #'s of air in my tires...always say that's too high....I know that's what the car likes and I see so many other guys on here run up there too.
Next project is to take off the 6 pak and try the Victor and a 950 HP ultra....I'm thinking she'll go faster yet....
Re: Dead-hooking FINALLY... [Re: superwrench] #1471971
07/22/13 12:50 PM
07/22/13 12:50 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
I run my 29x9 Hoosiers at 18#.
Re: Dead-hooking FINALLY... [Re: moparguy7074] #1471972
07/22/13 01:29 PM
07/22/13 01:29 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats great to hear. My best 60 is a 1.50 on just SS springs but your 60 is very good now. Congrats on the new best et also. I run the 30 x 9 Hoosier radial slicks at around 16 psi. My best 1/8 is 6.83 so you have easy 10.70's. Ron
Re: Dead-hooking FINALLY... [Re: superwrench] #1471973
07/22/13 03:17 PM
07/22/13 03:17 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Great going
Is that 30x9 hoosier a radial slick?
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Dead-hooking FINALLY... [Re: Dap] #1471974
07/22/13 04:37 PM
07/22/13 04:37 PM
Great going
Nope...18200 with the D05 compound.....guys use them in Stock Eliminator. You could tell they were sticky before I even mounted them. All I can say is even when the track went away on us on Saturday evening, the 60' was still a 1.50. I f I had had the old tires on there, I'd guarantee you the 60 woulda been a 1.60 or worse.
I'm certainly pleased....I'm gonna try a bit more pressure and try some preload on the bars. At least I have a base point now.
Re: Dead-hooking FINALLY... [Re: superwrench] #1471975
07/22/13 11:07 PM
07/22/13 11:07 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
It was nice to see the Pink Pig flying.
