Suddenly my 340 doesn't want to idle hot? #1471848
07/21/13 10:39 PM
07/21/13 10:39 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
As disclosed in the past, I'm am no mechanic.
I have a rebuilt stock 71 340 with a Harms built thermoquad. I just got the car running mint and it has about 600 miles on it now. The last two times I drove it, it starts up and runs perfect until it get hot then it does not want to idle in drive. It will stall at red lights if I don't put the car in neutral. It starts right back up but I have to hurry up and rev it up and throw it into gear to get it to take off with out stalling. Tonight, I tried to raise up the idle a bit cause I thought it was a little low (about 700 in neutral). I was doing this after driving it home from a cruise (running for about 25 minutes).
I raised the neutral idle as far as I could with the idle screw (about 840) and after that the car wants to stall every time I put it in gear. The car was running another 10 minutes or so while I adjusted the idle so it was pretty warm at this point. It also now seemed to be loading up a bit like it was choking out. (even in neutral) This is the first time it has acted like this since I got it running good.
Any ideas on what could be going on? I will have to get my mechanic to look at it but I am trying to learn as I go so I always start here.
You guys rock. As always, thanks for any help..
Scott
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: Suddenly my 340 doesn't want to idle hot? [Re: fireeng] #1471849
07/21/13 10:49 PM
07/21/13 10:49 PM
Eng off. Take out the idle mixture screws (Turn them in first to lightly seated & count the # of turns so you can easily return them to their original position when done). fit one of those thin red straws to a can of starting fluid & shoot a 2 second blast into each hole in the carb base then replace the screws.
Re: Suddenly my 340 doesn't want to idle hot? [Re: RapidRobert] #1471850
07/22/13 10:18 AM
07/22/13 10:18 AM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Thanks, I'll give this a try. Can you elaborate on what might be going on and what the starting fluid in there is doing? Just trying to educate myself. Thanks!
1971 Challenger
2013 Jeep Wrangler
Re: Suddenly my 340 doesn't want to idle hot? [Re: fireeng] #1471851
07/22/13 10:25 AM
07/22/13 10:25 AM
Sure bro. Dirt in the idle passages & the idle system has the smallest passages & are the easiest to plug up. Starting fluid cleans em. The only thing that makes me think that this might be something else as in heat related with the fuel is that it only happens when hot but blasting the 2 holes clean is easy to do & has happened to me several times on my eddy 1406, it would die at idle. Had to blast it several times in a month then I put on a new fuel filter & been good for months now. E10 (ethanol) corn gas will do it but I'm assuming you have not changed gas stations
Re: Suddenly my 340 doesn't want to idle hot? [Re: RapidRobert] #1471852
07/22/13 10:57 AM
07/22/13 10:57 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree with Robert on this. When a fresh carb is running properly and suddenly has issues its almost always a fuel contamination issue. The only other two carb related issues that affect performance on a new carb are a bad float (even brand new ones occasionally have tiny pin holes causing slow leaks). A bad needle and seat, or a bad acc. Pump (todays fuel is hell on both). Based on your description Id go with fuel contamination as my first guess follwed by some non carb issue like ignition.
Re: Suddenly my 340 doesn't want to idle hot? [Re: ScottSmith_Harms] #1471853
07/22/13 11:43 AM
07/22/13 11:43 AM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
This is what I am dealing with right now. Car ends up sitting for sometimes an extended period. Slowly (or suddenly) car is hard to start and runs like crap. I take a look and carb insides are trash. I have them apart now awaiting new gaskets. I just asked/posted the question as to the best solution to clean with. Scott, these are a pair of your "repo-hemi carbs"... what would you suggest to soak in or clean with? I don't want to hurt the platings at the linkage. I hope I'm not causing a foul here by asking my post again in this thread but it seems related.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Suddenly my 340 doesn't want to idle hot? [Re: 426runner] #1471854
07/22/13 12:46 PM
07/22/13 12:46 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem, as mentioned, bad fuel or dirty fuel systems are hell on carbs. I recomend a mild cleaner like Simple Green to clean them, harsher chemicals such as carb cleaner will often remove the subtle plating details. In the mean time Id take a hard look at every other component of your fuel system to find the source of the contamination. If you think its just residue from evaporated fuel try using a quality fuel stabilizer before parking it for long periods. You could also run the carbs dry before storage which sometimes helps.
Re: Suddenly my 340 doesn't want to idle hot? [Re: ScottSmith_Harms] #1471855
07/28/13 08:23 PM
07/28/13 08:23 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I tried what Robert suggested, blasted out the ports and changed the fuel filter. Same as before, car runs fine for 25 minutes or so then doesn't want to idle. Some suggested putting in a thicker gasket between carb and intake but my air cleaner hits my hood pad now at the current height. Any other suggestions? Thanks
1971 Challenger
2013 Jeep Wrangler
Re: Suddenly my 340 doesn't want to idle hot? [Re: fireeng] #1471856
07/28/13 11:43 PM
07/28/13 11:43 PM
You might add the thicker carb base gasket & run it with the hood blocked open enough to clear & if that takes care of it then we're on the right track. I forgot are we running E10
Re: Suddenly my 340 doesn't want to idle hot? [Re: RapidRobert] #1471857
07/29/13 03:48 PM
07/29/13 03:48 PM
P
Paul_Fancsali Offline
P
Try a different brand of gas and see if it makes a difference the swill called gas now is total crap
Re: Suddenly my 340 doesn't want to idle hot? [Re: Paul_Fancsali] #1471858
07/29/13 07:03 PM
07/29/13 07:03 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
71 340's had a aluminum spacer plater under the carb about 1/4". Why is your air cleaner hitting the pad? Is the engine 100% stock? Might be a fuel pump or filter, where is the initial timing set at?
Re: Suddenly my 340 doesn't want to idle hot? [Re: ademon] #1471859
07/29/13 07:45 PM
07/29/13 07:45 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
My bad, may car was restored to look stock. In reality it has a 72 block and I believe a 73 spread bore intake with a 74 TQ. No spacer in there now. I think the timing was set at 13 degrees BTDC. I am going to recheck the timing tomorrow to see if that is where its at.
I just filled up with the same gas I have been running in it all along, so the next tank I will switch it up and see if there is a difference.
1971 Challenger
2013 Jeep Wrangler
Re: Suddenly my 340 doesn't want to idle hot? [Re: fireeng] #1471860
07/29/13 07:52 PM
07/29/13 07:52 PM
I think the timing was set at 13 degrees BTDC. so the next tank I will switch it up and see if there is a difference.
13 ain't retarded unless the cam is pretty radical & this did happen all of a sudden I believe. Are we using ethanol (E10)?
Re: Suddenly my 340 doesn't want to idle hot? [Re: fireeng] #1471861
07/29/13 08:24 PM
07/29/13 08:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Electric fuel pump unless you like driving it like it is ...
Re: Suddenly my 340 doesn't want to idle hot? [Re: RapidRobert] #1471862
07/29/13 09:26 PM
07/29/13 09:26 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Cam is pretty close to stock for a 71 build. This issue did just start this season (carb was changed over the winter). I think I am using E10, I believe that is all that is available around here.
I guess electric fuel pump is an option if I can't get any other way to work.
1971 Challenger
2013 Jeep Wrangler
Re: Suddenly my 340 doesn't want to idle hot? [Re: fireeng] #1471863
07/29/13 09:43 PM
07/29/13 09:43 PM
I may be off base here but I would think that the hot idling dieing problem is from the combo of E10/heat not a fuel delivery inadequacy that an elec pump would fix. EDIT could you plumb in a can of race gas or any available fuel that has no ethanol in it to the pump inlet & see if the problem goes away? But if an elec pump will pressurize the ethanol & solve this I stand corrected
Re: Suddenly my 340 doesn't want to idle hot? [Re: RapidRobert] #1471864
07/29/13 10:26 PM
07/29/13 10:26 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
IDK the answer, just taking all the suggestions I can get and passing them on to my mechanic......
1971 Challenger
2013 Jeep Wrangler
Re: Suddenly my 340 doesn't want to idle hot? [Re: fireeng] #1471865
07/30/13 09:49 AM
07/30/13 09:49 AM
Nebraska
Dodge-N-Shelby Offline
Nebraska
In the last 2 weeks I have been fighting a similar problem with the 383 in my 65 Newport. Runs great for 20-25 minutes until it warms up good and then dies when I pull up to a light, slow down to turn, etc. I replaced my 1405 Eddy with a NIB 1405 after fooling with the 1st one, I pulled the intake and blocked the heat ports since I don't need them (trying cool the bottom of carb). A friend suggested that I may have a problem with the electronic ignition swap that I did recently so I tried a new distributor. I ended up dropping my original points distributor in and it runs great. I am guessing that I have either a loose wire or bad box but now that its running good, I will mess with it during winter storage. Just saying that you are not alone and goofy things happen. btw, I am running E-10 with a stock fuel pump and my first thought was that it was vapor locking.
Re: Suddenly my 340 doesn't want to idle hot? [Re: Dodge-N-Shelby] #1471866
07/30/13 10:17 AM
07/30/13 10:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Interesting that this fixed itself with a distributor change. how old is that distributor ? IS it an OLD Chrysler unit or the new mallory unit ?
Re: Suddenly my 340 doesn't want to idle hot? [Re: JohnRR] #1471867
07/30/13 04:48 PM
07/30/13 04:48 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Let me ask. If vapor lock was causing my idling problem wouldn't it also make the car hard starting when hot? When my car does stall after its been running awhile it has always started right back up.
1971 Challenger
2013 Jeep Wrangler
