Re: Adapting a Mopar starter to a Ford starter solenoid?
[Re: RapidRobert]
#1471520
07/21/13 05:29 PM
07/21/13 05:29 PM
Posts: 96 Oregon
Badge
[Re: Badge]
#1471521
07/21/13 05:57 PM
07/21/13 05:57 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The Ford unit has two large posts. Battery/fuseable link to loom in, and power out to starter. It also has two small posts marked I and S. I supplies power to the coil at full 12 volts. The S is for the neutral safety switch.
The S terminal is Start power from the starter switch, the solenoid must be grounded to complete the start circuit; the I and S unit can't be used with a NSS unless there is an ISO relay in the circuit. (see diagram below)
To use a NSS with that type of solenoid you need the unit that has two unlabeled small terminals, one terminal is power from the starter switch and the other is grounded through the NSS (you'll lose the ignition boost)....the solenoid doesn't need to be grounded.
[Re: John_Kunkel]
#1471522
07/21/13 06:11 PM
07/21/13 06:11 PM
RapidRobert
John, so there are 2 types of those type of furd solenoids? & what is the ISO relay? EDIT I think I got it, one is a regular 4 terminal relay & the other is the furd type with the 2 small terminals labeled S and I. I think a momentary contact switch sending fire to the S terminal & you're good (if the metal base is grounded). Not sure what setup you have with the NSS
[Re: RapidRobert]
#1471529
07/23/13 02:42 AM
07/23/13 02:42 AM
Posts: 606 Montana
Yancy Derringer
Montana
Ford never used a Mopar NSS circuit (to be clear.) BUT AMC did. It "looks like" a Ferd solenoid, has the I and S terminal, and an additional "quick connect" bullet terminal which gets grounded through the NSS. I assume these were used in some AMCs with Torqueflites Those solenoids are expensive and difficult to find. Frankly, why not just leave the Mopar start relay as it is, then run the square solenoid terminal back to the Ford solenoid? Last, I see no reason to do things that way, IE use a second solenoid. I see no advantage, and you add a second set of contacts in series, so you have that much more chance of voltage drop problems. Here's the AMC relay / solenoid. The NSS terminal is the one sticking up vertically http://www.rockauto.com/catalog/moreinfo.php?pk=929440&cc=1003509annudder There IS one other way you could use just a Ferd solenoid with a Mopar NSS, although some might say "hokey." You could mount the Ferd solenoid on an insulator block, and hook the NSS switch to the Ferd mounting flange.
[Re: Magnum]
#1471531
07/25/13 02:54 AM
07/25/13 02:54 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
, Last, I see no reason to do things that way,
Go back 2 replies and read 383man explanation.
In a battery in trunk set up. It leaves the hot wire dead. Excellent set up!
Or running the starter load through a cut off which burns them up more quickly.
I do mine like 383 posted, except everything on my cars outside a 2' cube around the battery ends up DEAD when you throw the cut off!
When you have/see a car burn up because of live wires, you'll understand.
