60mm small block cam question
#1471457
07/21/13 01:35 PM
07/21/13 01:35 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
i was wondering if any of you know if the fireing order is standard or different? And one more was LSM the guys who provided these for ma mopar? thanku guys.
Re: 60mm small block cam question
[Re: fishy340]
#1471458
07/21/13 03:45 PM
07/21/13 03:45 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
LSM was one company I think a couple guys did them. There were a couple firing orders too if I recall correctly.
My cam was a double swap but, I think there were some that just swapped 7&4. It is easy to look at a cam and figure it out.
Just take a marker and mark the intake lobes. You can use a different color for the right and left banks to disrupt confusion. Then simply roll it across a flat surface counting off the firing order. There are only three possibilities.
18436572 18736542 18726543
After counting three intake events you should know which cam you have.
Leon
[Re: Leon441]
#1471459
07/21/13 05:30 PM
07/21/13 05:30 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The firing order sway is basically making it a ford Windsor firing order. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: fishy340]
#1471461
07/21/13 08:02 PM
07/21/13 08:02 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
is this a power adder motor or N/A. how much separation do you need those ugl cams really limit your choice's.. 60 mm blank cores are not cheap I think comp gets 1000$ for a core but not sure. that is why I used a 55mm cam core.... 300$ core
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1471462
07/21/13 08:08 PM
07/21/13 08:08 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
My BB are 60mm custom from LSM I use a LS1 firing order, although I don't get them to grind them.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: AndyF]
#1471466
07/22/13 06:47 PM
07/22/13 06:47 PM
Leon441
Lynchburg, VA
I am not going to argue this until I am blue in the face. Just no point.
Fords are offset backwards from bank to bank. How can you share a firing order with an engine that does not even have the cylinders in the same arrangement with each other?
[Re: AndyF]
#1471469
07/22/13 07:38 PM
07/22/13 07:38 PM
Leon441
Lynchburg, VA
Crankshaft loading is only part of why firing orders are selected as preference.
Sure a HO 302 Ford or mopar with a 7/4 3/2 swap will load the same crank throws at the same time but, I would hardly say from an engineering standpoint that one compares to the other. Maybe if you are strickly trying to engineer crankshaft load placement.
Intake manifold design and RPM is one of the reasons most engine builders I have talked to choose alternate firing orders.
None of this discussion has much to do with what the OP was asking.
Leon
