Do I need a stronger clutch? #147139
11/08/08 01:41 AM
11/08/08 01:41 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Or is it me the driver? I have now gone thru 3 clutches in the last 4500 miles. The first one was a centerforce dual friction unit and it was great until I took my car to the track with some dot drag tires and fried it. The first one I got about 8 passes out of it until it started to smell and all free play went away and the pedal became very stiff. When I pulled it, it was down to the rivets on the clutch disk and blued the flywheel. I then bought a mcleod unit that was told would work with my car about 700hp and 650+tq. Well that did not last more than 3 passes and was toast. I then reinstalled the current one another centerforce and took the car to the track a few weeks back and it did the same as the first and now has a stiff pedal though it is not slipping yet. I now need to do it again and wondering what you 4spd boys would suggest?
Re: Do I need a stronger clutch? [Re: SCATPK] #147140
11/08/08 01:50 AM
11/08/08 01:50 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Herb for the amount of hp your motor is putting out, I think your right on the envelope of a racing clutch. I think you should be using a street twin clutch. Alittle pricey thou.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Do I need a stronger clutch? [Re: SCATPK] #147141
11/08/08 01:50 AM
11/08/08 01:50 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Seems like you've bought the best stuff out there, you would think it would take a few launches, thats why you step up to the good stuff rather than buy the cheap stuff I bought when I was younger...Every couple months... I think I'd be contacting Centerforce for their recomendations..
Re: Do I need a stronger clutch? [Re: 1_WILD_RT] #147142
11/08/08 02:00 AM
11/08/08 02:00 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
I have been buying the best out there or at least that is what I thought. I have bought nothing but good parts from the clutch, flywheel and hardware and still having issues. The bellhousing is perfectly centered and all linkage is correct and straight and operating properly. Thinking it may be the burnouts in second gear with the line lock that is killing them? Figuring that it fighting my 2 front tires that are locked 265-50-15 meats and trying to spin 325-50-15 et radials, sound like a good reason? I figure the best way to eliminate any more headaches is to just stop taking it to the track and keep it on the street where there never seems to be an issue.
Re: Do I need a stronger clutch? [Re: SCATPK] #147143
11/08/08 02:04 AM
11/08/08 02:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would hardly put a centerforce in the catergory of the best clutch out there , but thats me .
Herb , you are going to have to spend a pretty penny on a clutch to live behind that motor . But one thing you need to remember is its a clutch and its a WEAR ITEM , it's not going to last forever drag racing it .
Street twin and stop racing if you want it to last forever .
Re: Do I need a stronger clutch? [Re: JohnRR] #147144
11/08/08 02:11 AM
11/08/08 02:11 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Figured that would be the answer. I bought a sfi flywheel last year and have heard that there is a street twin available that can be used behind my flywheel without buying a complete package. I hate to have to buy another flywheel again and would like to avoid it if it will live and work properly. John, I know that I am dealing with a wear item but would like to get a bit more wear out of it!
Re: Do I need a stronger clutch? [Re: SCATPK] #147145
11/08/08 09:25 AM
11/08/08 09:25 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
3.54 gears with ET radials and burn out starting in 2nd. gear.
This is probably a major item for taking your clutch out.
If you do take it back to the track,
start your burn out in 1.st just hold it steady at about 4K. I think you will see a lot longer clutch life.
Re: Do I need a stronger clutch? [Re: cyphre666] #147146
11/08/08 10:26 AM
11/08/08 10:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
good point , thats going to hurt it pretty quick , but he's got alot of torque so it should start pretty easy .
He needs to look at race clutch linings , they are harder to street drive but can handle being heated
Re: Do I need a stronger clutch? [Re: SCATPK] #147147
11/08/08 11:06 AM
11/08/08 11:06 AM
twin cities
dart_sportsatellite Offline
twin cities
When you do your burn out, are you revving the engine up and dumping the clutch?
Re: Do I need a stronger clutch? [Re: dart_sportsatellite] #147148
11/08/08 12:28 PM
11/08/08 12:28 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
I have been reving it up to about 2000rpm in 2nd and letting the clutch out while holding the line lock and it spins the tires very easily. I do not need the line lock just keeps the car from pushing forward. I had someone take a video of me at the track and after the 2nd or 3rd pass you could see smoke coming from the bellhousing area while I was doing my burnout. I am not doing any John Force ones either just enough to get the tires warm. I have been doing my burnouts this way for a number of years and have never had any problems. Not sure why I suddenly have an issue though I think it may be the large rear tires. The strange thing is if its the tires grabbing and being sticky during the burnout then why do they spin like a dental tool on the leave from the tree? I have suspected that the burnout is the major cause of my issues and as said should probably just spin the rears in 1st and hope for the best.
Re: Do I need a stronger clutch? [Re: SCATPK] #147149
11/08/08 01:00 PM
11/08/08 01:00 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
what type of clutch disc?
does it look like this?
Re: Do I need a stronger clutch? [Re: ThermoQuad] #147150
11/08/08 01:34 PM
11/08/08 01:34 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
No it does not!
Re: Do I need a stronger clutch? [Re: SCATPK] #147151
11/08/08 01:44 PM
11/08/08 01:44 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think with a lineloc that a second gear burnout shouldn't put too much hurt on your clutch. I wouldn't slip it for the burnout, I would just let it out fairly quick.
I don't think centreforces are up for your horsepower level.
Street twin.
Sheldon
Re: Do I need a stronger clutch? [Re: SCATPK] #147152
11/08/08 05:19 PM
11/08/08 05:19 PM
ThermoQuad Offline
ThermoQuad  Offline
For your application you need the disc as shown in the photo. It sounds like you have a regular style disc with a full marcel [s shaped spring in the middle of the disc] which does not hold up under adverse conditions.
The paddle disc has no marcel and uses metallic pucks which significantly reduces the release and lock up time when shifting...like night and day. As far as drivabilty with the paddle disc there are no issues as long as the concentricty of the b-h
is correct. There is a new metallic friction material avail now as well.
A custom clutch is what you need, if you want to go that route and end your pain:
Rochester Clutch and Brake
585-232-3717 Mon-Thurs 8-4 pm
Talk to Sam Jr he speaks mopar and clutch fluently
Re: Do I need a stronger clutch? [Re: ThermoQuad] #147153
11/08/08 07:38 PM
11/08/08 07:38 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Tom, any thoughts on the dual disk setups? I see you road race your car and have read your posts in the past so believe you have some actual real world experiance. Not sure if you know what the centerforce looks like but here is a link to some pics of one. http://www.performancecenter.com/clutche...ssure-plate-kit
And the clutch guy is he in new york?
Re: Do I need a stronger clutch? [Re: SCATPK] #147154
11/08/08 08:17 PM
11/08/08 08:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used to fry clutches until I put a little more gear in the car.A 4.10 gear would be alot easier on the clutch.You are trying to move alot of weight with not much mechanical advantage so something has to give.If you love your transmission do not put a mega stiff clutch in front of it
I put a Street-Twin in my car and split a brand new Liberty 3-4 slider on the third pass.
Gus
64 Plymouth Savoy
Dana 60
Re: Do I need a stronger clutch? [Re: fourgearsavoy] #147155
11/08/08 08:26 PM
11/08/08 08:26 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Gus, are you saying to stay away from the mcleod street twin clutch? I see they now offer the rst that you can use your stock flywheel. Are those things noisy with the 2 disks floating around?
Re: Do I need a stronger clutch? [Re: SCATPK] #147156
11/08/08 08:36 PM
11/08/08 08:36 PM
Rittman Ohio
Rittman Ohio
I would say it's a great street clutch that NEVER slips but that is what makes it a bad clutch for a heavy drag car with good traction.There is another member here,Mike67net that had a major transmission failure just after he installed a twin in his drag car too.My new clutch has an adjustable plate that can be tightened up for the street and loosened for the track.The other issue I had with the twin was too much inertia for a crisp and clean power shift.With both of the discs and a floater in there it wont release quickly enough for a clean disengagement.
And no they don't rattle.
Gus
64 Plymouth Savoy
Dana 60
Re: Do I need a stronger clutch? [Re: fourgearsavoy] #147157
11/08/08 08:38 PM
11/08/08 08:38 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Gus, thanks for the input!
