Re: Driveline vibration?
[Re: rck850]
#1471382
07/21/13 10:50 AM
07/21/13 10:50 AM
Posts: 1,106 michigan
440whiteboy
michigan
have you thought about the rear end? I had a Newport station wagon that would do the same thing. turned out it was the bearings.
also double check all wheels for balanced with front end alignment -
tires could be a problem for un eveness/out of round?
They only see Stars... when hit by a Mopar!
[Re: rck850]
#1471384
07/21/13 03:41 PM
07/21/13 03:41 PM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
You might also check the driveshaft-to-pinion angle. Incorrect angle can give you vibrations.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
