Driveline vibration? #1471380
07/21/13 08:45 AM
07/21/13 08:45 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Have a dead stock 74 Roadrunner 360 4 speed. Between about 70-75/80mph there is a vibration. It is even more pronounced when I let off the throttle after a quick dash to freeway speeds.
This car has never been modified. It only has 22,000 miles on it. It has always had this vibration even after replacing the clutch, flywheel, new fan clutch, and then having the original driveshaft checked and rebalanced. If I cruise the freeway at 60-65 the car cruises nice and smoth and quiet. If I crank it up above 80 same thing but in that one area it sounds terrible.
Any thoughts on things to check? Thanks
Re: Driveline vibration? [Re: rck850] #1471381
07/21/13 10:46 AM
07/21/13 10:46 AM
that the front yoke has enough engagement into the trans (was the problem on my 904). I'm thinking driveshaft/ujoint & one guy on here had to have his shaft checked/rebalanced several times (by a diff shop iirc) till it was corrected. Might be runout on the pinion yoke flange.
Re: Driveline vibration? [Re: rck850] #1471382
07/21/13 10:50 AM
07/21/13 10:50 AM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
have you thought about the rear end?
I had a Newport station wagon that would do the same thing.
turned out it was the bearings.
also double check all wheels for balanced with front end alignment -
tires could be a problem for un eveness/out of round?
They only see Stars...
when hit by a Mopar!
Re: Driveline vibration? [Re: 440whiteboy] #1471383
07/21/13 12:48 PM
07/21/13 12:48 PM
ill
dennismopar73 Offline
ill
Just a thought here, I have seen wrong U joints put in before, caused the drive shaft to slide up and down inside the joints??
jmo
Re: Driveline vibration? [Re: rck850] #1471384
07/21/13 03:41 PM
07/21/13 03:41 PM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
You might also check the driveshaft-to-pinion angle.
Incorrect angle can give you vibrations.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Driveline vibration? [Re: rck850] #1471385
07/21/13 03:43 PM
07/21/13 03:43 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
my 19K mile hemi car did the same thing..new slip yoke and cured!
