Re: detonation vs compression, static or dynamic??
[Re: dogdays]
#1471177
07/23/13 08:19 PM
07/23/13 08:19 PM
Posts: 6,295 U.S.
moparniac
U.S.
Altitude will affect dynamic cranking compression and dynamic compression ratio. The cooler weather racing will cause the numbers to go up. So "figure" up your pump gas build at zero altitude type racing weather. The cam specs your posted do not show timing events either the higher the Intake Valve closing ABDC greatly helps.
Mopar Performance
[Re: moparniac]
#1471178
07/23/13 08:38 PM
07/23/13 08:38 PM
Posts: 4,210 New York
polyspheric
New York
"Altitude will affect... dynamic compression ratio."
How?
Boffin Emeritus
[Re: Kern Dog]
#1471180
07/23/13 10:23 PM
07/23/13 10:23 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The Dynamic compression "ratio" stays the same, but the cylinder pressure is reduced with altitude. A dynamic compression ratio of 8:1 should create cranking cylinder pressures of about 163.5 psi at sea-level (14.7 psi air pressure), but around Denver, the air pressure is around 12.0 psi, so the same engine (dynamic compression of 8:1) would only have a cranking cylinder pressure of about 133.5 psi. FWIW, 7:1 dynamic at sea-level (137.2 psi) is about the same cylinder pressure as 8:1 dynamic in Denver.
[Re: 451Mopar]
#1471181
07/23/13 10:46 PM
07/23/13 10:46 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
2000 ft to 4000 foot and 95 degrees, factory timing on my mac mentor shows around 30* at and near WOT. Never heard of a 318 getting a death flash only 5.9s. I actually had more pinging before milling the block and going to thinner head gaskets.
