Re: ABS light is on
[Re: 416scamp]
#1471096
07/21/13 01:38 AM
07/21/13 01:38 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
typically it is s the speed sensor in the rear axle. Parts stores or Mopar have them in stock. try pulling the battery cables for a few minutes and resetting the code. to see if that clears it.
Re: ABS light is on
[Re: sthemi]
#1471097
07/21/13 08:52 AM
07/21/13 08:52 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Also to along with what sthemi said, at some point on those trucks, (can't remember if it's early years or later years), but some of them have a short pigtail harness that went from the chassis to the speed sensor in the rear that would get corrosion in it and set the light off. Check to see if you have this jumper harness, because if you do, I would be inclined to replace this first over the speed sensor.
Outcast Dodge guy.
Re: ABS light is on
[Re: sthemi]
#1471098
07/21/13 08:54 AM
07/21/13 08:54 AM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
Pull codes.Unless you do you are just guessing as to the problem.Hard codes will not be erased by pulling the batt cables.Ive seen people at the shop who spent a bundle so they didnt have to pay for a diag.Most times it was cheaper to fix than what they spent.Look for leaks in the system also.Rocky
Chrysler Firepower
Re: ABS light is on
[Re: 416scamp]
#1471100
07/24/13 11:44 PM
07/24/13 11:44 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Speed sensor or tone ring sensor? Just curious. The newest I own is a 93 and the speed sensor is still in the trans or t-case. Rear has a tone ring sensor on mine. I just removed my tone ring sensors, and removed the ABS light on the dash. Fixed that issue!
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
