1971 340 Exhaust Manifolds #1471026
07/20/13 07:27 PM
07/20/13 07:27 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I recently bought a couple sets of 1971 340/360 B,C, and E-body exhaust manifolds (ebay) and found something I hadn't seen before. One set had earlier casting dates, and the other had later dates. The odd thing is that the passenger side later date piece (March of 71) had never been machined for a heat riser assembly. It is in super condion but has been on an engine for quite some time, I'm guessing it was a REAL early replacement part sold over the counter? Maybe from some oddball truck application with a hand choke? Have any of you seen one of these?
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471027
07/20/13 07:27 PM
07/20/13 07:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471028
07/20/13 07:28 PM
07/20/13 07:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The early one for comparisons
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471029
07/20/13 07:30 PM
07/20/13 07:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Casting #
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471030
07/20/13 07:39 PM
07/20/13 07:39 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Non automotive 340 or 360 application.
Boat? But they don't have those type manifolds like that do they?
Would a 360 Motorhome have to have a heat riser? I would think so?
What about a stationary 360 2V engine?
Re: 1971 340 Exhaust Manifolds [Re: autoxcuda] #1471031
07/20/13 07:42 PM
07/20/13 07:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, I don't know, could be any of the above. The drivers side was a correct 1971 C/B/E body 340 & 360 piece as well with similar date code and identical condition so they came together on something.
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471032
07/21/13 02:07 PM
07/21/13 02:07 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Any guesses why the e bodies went to the long type in 71 but the a bodies still had the upswept type.
Re: 1971 340 Exhaust Manifolds [Re: formula_s] #1471033
07/21/13 02:09 PM
07/21/13 02:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My guess is that it had something to do with the routing of the rest of the exhaust system. The 70-71 change from single to dual E-brake cables might have been a factor.
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471034
07/22/13 11:16 AM
07/22/13 11:16 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
I have one also, it came off a 340 duster.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 1971 340 Exhaust Manifolds [Re: davesmopars] #1471035
07/22/13 12:54 PM
07/22/13 12:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Really! What is the casting date? How about the spd of the Duster?
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471036
07/22/13 02:33 PM
07/22/13 02:33 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
The exhaust manifolds I used on my 360 in the Sport Satellite are from a 72-73 Road Runner. Base engine being a 318 - however, the manifolds have the port size for the 340/360 heads. AND the right side was never drilled for the heat riser, like the manifold you have pictured. Also, the right side has 318-RR cast in it (upside down). . .
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471037
07/22/13 03:46 PM
07/22/13 03:46 PM
Frederick , MD
GibW340 Offline
GibW340  Offline
Frederick , MD
no heat riser- I have seen exhaust manifolds from small blocks with no heat riser- and were definitely off a car- I don't know why not? Maybe sales in South or SW- or if no heater ordered??? Assuming warm environment- Seems weird when consider emission of late 60s early 70s probably required when cold started?
Re: 1971 340 Exhaust Manifolds [Re: a12rag] #1471038
07/22/13 03:56 PM
07/22/13 03:56 PM
Marion,Indiana
Seth_Jones Offline
Seth_Jones  Offline
Marion,Indiana
The set I bought for my 74 360 duster clone were not drilled for heat riser either.The are dated Jan of 74 IIRC.I thought it had something to do with 74 being the first year for EGR but your manifolds throw that out the window.
Re: 1971 340 Exhaust Manifolds [Re: Seth_Jones] #1471039
07/22/13 05:47 PM
07/22/13 05:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I wonder if single exhaust cars had/needed a heat riser?
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471040
07/22/13 06:33 PM
07/22/13 06:33 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
73 duster casting date 11 6 72
mcodecuda@yahoo.com
Re: 1971 340 Exhaust Manifolds [Re: davesmopars] #1471041
07/22/13 11:36 PM
07/22/13 11:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, with a few examples existing it's becomming evident that at least some cars might have recieved the non heat riser style from the factory. Now, what can we put together to determine which cars recieved heat riser assemblies and which cars did not, and then why?
Re: 1971 340 Exhaust Manifolds [Re: ScottSmith_Harms] #1471042
07/23/13 11:04 AM
07/23/13 11:04 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Thats what I have on my Duster. I think the guy I bought if from thought it was for truck.
