I bought a 72 Satelite a few years ago--128,000 miles, #'s matching 400 inch motor, but was a factory 2 barrel car. Previous owner had tried to make it like a 4bbl magnum motor by swapping on a 1970 factory iron 4bbl manifold, Holley carb , a "magnum" cam, dual 2.5" exhaust thru hi-po 72 exhaust manifolds. Still running factory non electronic ignition distributor. Stock heads. No receipts for work done.*****
It never seemed to run great, and he offered an extra parts carb w/ sale. [ Clue # 1 ?? ]-- Car ran well enough to drive it an hour home , and around town, but it felt like it was slightly surging when driving at a steady speed, and not too strong which i attributed to the 2.76 gears.*****
Since it was a non elect ignition car , i was going to go FBO conversion and had him curve a distributor for it. Ended up putting in a MSD dist / 6A digital box / coil+wires. I set intial timing where FBO had recommended , at 14 before, and left the slower MSD installed springs in the distributor. Car ran better and i thought surge mostly went away, till it came back.
Got rid of the Holley which didn't look the best/ mismatched colors / maybe had been rebuilt from diff carbs ? -- bought a new edelbrock performer thunder series, the larger size [750/800cfm?]. Base Tuned it to their instructions, getting about 15-16 inches vacuum. Car ran better. now you could feel the secondaries of the carb. Also had put in 3.55 rear gears , dumping the 2.76's.
Car ran pretty well for a few short trips, then acted like it hardly wanted to stay running at idle / carb very hot / heat induced vacuum lock ? ---when cooled down ran ok in driveway next day. Checked timing and reset it to 12 degrees initial to try to create less heat. But at idle timing is jumping from 11 to 13 degrees or 10-14' not staying on 12', rev it up and the timing doesn't drift. So figuring it needs a timing chain. ******
Ok, so Got a 1/2" fiber wood spacer and a thicker 3/8" gasket, and pulled the Chrysler iron 4bbl manifold to swap in a Weiand stealth style 8008 aluminum and a valley pan with heat crossover blockoffs. Thinking to get the carb cooler. Looking in to the valley i see previous owner replaced 1 of the pushrods and 6 of the rocker arms. The lifters look newer. The cam is a Delta regrind where the specs were very close to a factory magnum grind , i want to say 214-220 degrees, but i lost the cam box when we moved. ******
Ok - finally questions -
Why replace only a few rockers and 1 push rod ? Cost ?
No gaskets under the intake manifold just RTV sealant ? Why ?
Did the factory put washers under the head bolts ?
it has all grade 8 head bolts but they are from 3 different lots/stampings ? Is that normal or was the head likely pulled at some point? DOesn't seem to blue smoke out the exhaust, and the black over rich smoke went away when i ditched the holley.
I'm fairly certain i'm going to find a stretched timing chain. So without knowing the cam specs exactly, do i just get a quality new chain and install "straight up", and hope for the best ? ******
I had already put in a edelbrock fixed 6.5 psi mechanical fuel pump, new fuel lines + filter, and a hi volume oil pump last year. Also a brand new northern radiator, dual electric fans, electric water pump.
Its a hobby car, i dont need it for daily use, I'm pretty good at bolt-on stuff, simple swaps, own some torque wrenches/basic auto tools, but i don't have the tools to rebuild an engine. Will a compression test alone be usefull - do i need a leak-down kit ? Advice ?
Lets assume i can pull together $2000 this year, should i pull motor, and hope its enough $$ for a machine shop rebuild. Or wait another year or two when maybe i can afford maybe $5000 and strive for a properly built stroker engine. I do have another fast car so i can fulfill that itch when necessary.
Thanks for your thoughts.
** edit to add , has a nice exhaust leak at manifold to head pipes, where either muffler shop or previous owner used bolts with Nylock plastic insert nuts to attach the two.
. Another reason to wonder whats going on in engine.
