67 Fury with 11x2 brakes #1470982
07/20/13 03:22 PM
07/20/13 03:22 PM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
Are the drums the same for front and rear?
Re: 67 Fury with 11x2 brakes [Re: Russ_Davis] #1470983
07/21/13 09:37 AM
07/21/13 09:37 AM
Andrewh Offline
Andrewh  Offline
if they are 2 all the way around sure.
but typically the front are 2.5 and the rear are 2.
HD got 3 up front and 2.5 in back as I recall.
Re: 67 Fury with 11x2 brakes [Re: Russ_Davis] #1470984
07/21/13 02:30 PM
07/21/13 02:30 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Are you asking if they are the same size or if you can swap them front to back?
Drums are ordered by size. The backing plate will determine the size as the hub or axle flange will always be on the same plane.
I have mechanical Aptitude.
I can screw up anything.
Re: 67 Fury with 11x2 brakes [Re: bboogieart] #1470985
07/21/13 03:44 PM
07/21/13 03:44 PM
Pittsfield, Mass.
Pittsfield, Mass.
The car has 11"x2" brakes all around, just wanted to know if the drums were the same front to rear. Thanks
Re: 67 Fury with 11x2 brakes [Re: Russ_Davis] #1470986
07/21/13 05:49 PM
07/21/13 05:49 PM
Connecticut
biginchmotor Offline
Connecticut
My 67 has 11 by 2 shoes only on the rear, John.
Re: 67 Fury with 11x2 brakes [Re: biginchmotor] #1470987
07/21/13 05:57 PM
07/21/13 05:57 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Front drums always have hubs with bearings in them so you can mount them on the spindle.
Rear drums just mount on the axle's flange. So no, the drums are not the same.
Re: 67 Fury with 11x2 brakes [Re: BigBlockMopar] #1470988
07/21/13 07:17 PM
07/21/13 07:17 PM
Andrewh Offline
Andrewh  Offline
drum is a drum by size only. no front or rear.
I don't ever recall seeing one sold with the hub. always had to junkyard that part.
the lug studs are swaged on, so that must be cut, or you will screw something up trying to pound the hub out of the drum.
Re: 67 Fury with 11x2 brakes [Re: Russ_Davis] #1470989
07/22/13 09:28 AM
07/22/13 09:28 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
The car has 11"x2" brakes all around...
Are you 100% sure?
Re: 67 Fury with 11x2 brakes [Re: Commando1] #1470990
07/22/13 10:24 AM
07/22/13 10:24 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've never seen a 11"x 2" drum on the front. That doesn't mean it doesn't exist though. I know for a fact my 73 4x4 p/u had 2" drums front and rear but the drums were not interchangeable from front to rear due to the centers being hub centric. I think typically the fronts are 3" and very often are a finned drum. rear 2 1/2" are typically finned also. I just sold a 67 Fury 1 and it had 11" x 2" on the rear (no fins) and what looked like a 2 1/2" on the front. (finned)
...FAFO...
