Stagger in front wheels???? #1470888
07/20/13 10:46 AM
07/20/13 10:46 AM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What are the real benefit in building stagger in the front end?? Is it worth it?? For my application the maxium is 1".
Re: Stagger in front wheels???? [Re: Blucuda413] #1470889
07/20/13 10:54 AM
07/20/13 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In the lights it makes your car like it has a much
larger tire.. which gives you a longer rolling start..
I have 3/4" stagger in my car which helps being I run
a fairly short tire
EDIT
Also if you do it.. set the right tire back.. the left
side wants to lift first because of the torque and
that keeps the right tire on the ground longer
Re: Stagger in front wheels???? [Re: MR_P_BODY] #1470890
07/20/13 12:07 PM
07/20/13 12:07 PM
PA
moparacer Offline
moparacer  Offline
PA
Increased RT and reduced ET from having more roll out is the main reason guys do it.
I have a set of A body factory upper control arms that were modified to give an inch of extra stagger. Pretty trick setup whoever did it.
What they did was offset the ball joint locations. Forward on one and rearward on the other.
Anyone has any interest in them I will probably put them in the classified for sale when I get the chance.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Stagger in front wheels???? [Re: Blucuda413] #1470891
07/21/13 12:14 AM
07/21/13 12:14 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
It was a "secret" mod that the stock and super stock racers used in 60s and 70s. One of many
Re: Stagger in front wheels???? [Re: 52savoy] #1470892
07/21/13 02:03 AM
07/21/13 02:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its regular thing on chassis cars
