Can I reseal Valley cover with Indy heads on engine?
#1470688
07/19/13 10:54 PM
07/19/13 10:54 PM
Posts: 233 vashon island washington
hunterstroble
Hi all, I have a 440, with Indy EZ heads and their solid valley cover with inspection plate. The valley cover is leaking in the front where the silicone is. Do I have to pull a head to reseal this or is their a way to reseal it with the heads on the engine. I searched but did not find any defenate answers. What silicone do you reccomend? I was going to use the Mopar ATF silicone unless there was a more suitible kind. Thanks.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
Re: Can I reseal Valley cover with Indy heads on engine?
[Re: hunterstroble]
#1470690
07/20/13 12:05 AM
07/20/13 12:05 AM
Posts: 4,647 aotearoa
rebel
aotearoa
no problem. clean up the area where it's leaking real good. spray some carb cleaner or other suitable de-greaser around the area to be sealed. lay out some masking tape on the perimeter edges where you want the sealer to stop & rtv away. lick your finger so the rtv dont stick & make it look tidy. peal off the tape & you wouldn't know you'd repaired it. i do this to seal my heads, i'm sure you can do similar to repair your leak.
[Re: hunterstroble]
#1470692
07/20/13 04:07 AM
07/20/13 04:07 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Some of the Mega blocks (like the one I own!) need to have a hump near the distributor ground off if you have to slide the valley plate out. I should buy a plate with the access built in!
[Re: hunterstroble]
#1470695
07/20/13 03:28 PM
07/20/13 03:28 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
On my old 500" low deck I had a local machine shop put a slanted cut down the center of my Indy plate so it could easily be installed or removed with the 440-1 heads installed. Worked great!
I'm also doing a pump gas 500" low deck for the new Duster with max wedge port Eddy heads so I don't know what I'm gonna use for a valley cover??
[Re: ProSport]
#1470697
07/21/13 01:58 PM
07/21/13 01:58 PM
Posts: 4,072 Mo.
racerx
Mo.
So what seals the machine surface cut rtv. ?
[Re: ProSport]
#1470698
07/21/13 03:54 PM
07/21/13 03:54 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I'm dealing with the same thing on my 500" blower motor. But since the heads are spaced up about .010" with Cometic gaskets, I've been thinking of doing a straight cut on the coverplate, and fill the gap with some aluminium edging in the form of a T-strip or something.
Andy's plate looks like a very nice piece but I can't see myself spending $250 on it at Mancini's.
[Re: BigBlockMopar]
#1470699
07/21/13 04:42 PM
07/21/13 04:42 PM
Posts: 31,050 Oregon
AndyF
The clear valley has been useful during dyno testing. We tracked down a couple of small oiling issues by watching thru the plate.
[Re: AndyF]
#1470702
07/21/13 10:36 PM
07/21/13 10:36 PM
Posts: 9,862 MI, usa
dvw
MI, usa
Re-sealing the valley plate without pulling the heads seems like a high risk deal. Guess it all depends on what you're trying to accomplish. If you have a vacuum pump it might work since you can put a bead on the outside and the vacuum will pull it in. If you have positive crankcase pressure then my guess is that you'll have a leaker until you pull the heads and do it right.
I don't agree. I've pulled the valley plate off 2 different Indy engines withe the heads on. Remove the intake, remove the 6 tray bolts, cut the RTV with a knife, slide the plate back and drop it into the valley. Then twist lift, remove, clean, and reinstall. Whats the big deal? I also thread the center 2 holes 3/8x24. Then screw a bolt into the plate to help split the China wall seal. Only a turn or so against the block does the job. Doug
