MP 4876129 manifold #1470674
07/19/13 10:23 PM
07/19/13 10:23 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
this manifold for the Stage 6 head, is it extra wide so you don't need spacers when installed on a RB engine? i want to install it on a B engine but conflicting stories has me thinking it is not going to fit. i live downunder & don't want to make a mistake & order a manifold that is not for my application. i know you use a 440 manifold for this combo but this MP manifold has the cast in valley tray which will fix that issue as well. the Stage 6 heads are max wedge ports.
Re: MP 4876129 manifold [Re: rebel] #1470675
07/19/13 10:52 PM
07/19/13 10:52 PM
AndyF Offline
AndyF  Offline
I don't think Mopar ever made a B version of the Stage VI intake. Only ones I've ever seen in the catalog were for RB engines with Stage VI heads. Zippy would know for sure.
Re: MP 4876129 manifold [Re: AndyF] #1470676
07/20/13 08:56 AM
07/20/13 08:56 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Isn't the "B-version" on a B-block just an RB intake dimensionally due to the raised runners?
I just got one of the RB specific intakes a few weeks ago. ALL of the internet websites that offer one new (like Summit Raacing) show ZERO stock and the site that I ordered one from does the "direct-shipping from manufacturer". They called me the first business day and informed me that they are no longer available. So I found mine on craigslist.
There's no way that intake will fit a B-block even with standard heads. I will mock it up this morning for fun but those ports on the intake are much further apart. And the top rail of the block mating surface is wider.
And of course,as cast, the intake ports are smallish, like Pontiac ports, but I suspect they're that way to let the builder open them up as they like.
Re: MP 4876129 manifold [Re: rebel] #1470677
07/20/13 10:03 AM
07/20/13 10:03 AM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
Indy rb manifold fits stage 6 heads on a low deck block
Re: MP 4876129 manifold [Re: avenger572] #1470678
07/20/13 06:38 PM
07/20/13 06:38 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i know that but no one makes a max wedge intake bathtub for a B engine & i'm not sure who supplies a valley tray for this combo either. the MP manifold has the built in valley pan so it's fixes 2 problems at once, that is if it fits which is what i'm trying to find out. after more research i'm thinking the MP4876337 manifold might be the right one. does anybody know where i could find blueprints of these manifolds so i can check the width at the base?
Re: MP 4876129 manifold [Re: rebel] #1470679
07/22/13 05:26 PM
07/22/13 05:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Going from memory here...
- MP made B & RB valley covers intended to work w/ the Stage VI heads, but they weren't exactly sophisticated... just stamped aluminum plates w/ the head-side edges turned up where they run into the heads
- I thought those MP covers were supposed to be sandwiched between the optional RB spacers and the heads themselves, which is how I used it on an RB w/ a standard-type RB intake
- Not exactly sure how the B valley cover would seal when using an RB intake that didn't use the spacers, other than a sh!tload of RTV along the edge where it butted up against the heads
- The '337 intake won't do what you're looking for since the integral valley cover of that intake will still sit way above the front & rear edges of the block, unless you fabricate some type of spacers like AndyF shows he made in his book to do something similar when using the '337 intake w/ Edebrock Victor heads
- The dedicated RB Stage VI intakes won't do what you're looking for either and, I suspect, would require cutting off the integral valley cover to even line up the ports
Maybe you can make something like, or possibly modify, the valley covers that either Hughes or 440 Source sell. I'd suggest fabricating your own to allow a wider strip of material on the head-sides of the plate, then drilling & tapping the cover & the heads (like the Victor covers) to enable putting sealant between them and tightening the cover in place better.
Just an afterthought, but maybe you can start w/ the Victor B valley cover and modify that to work w/ the Stage VI heads?
==> http://www.jegs.com/i/Edelbrock/350/7799/10002/-1
Re: MP 4876129 manifold [Re: rebel] #1470680
07/22/13 09:52 PM
07/22/13 09:52 PM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
I used an indy valley tray and just run a bead of ultra grey sealer along the seam ,worked perfect .
Re: MP 4876129 manifold [Re: BradH] #1470681
07/23/13 01:51 AM
07/23/13 01:51 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
how much of a gap do you think there would be? this is the part of the manifold i was concerned about, but glue in a spacer might be the easiest trick for my skill set.
Re: MP 4876129 manifold [Re: rebel] #1470682
07/23/13 10:18 AM
07/23/13 10:18 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, as said the 129 manifold won't fit the B engine application regardless of what cylinder head is used, because it is too wide.
The P4876337 could be made to work on the B engine/Stage VI combination, but it is not a 4500 flange like the 129 (not sure how important that was) and as said the integral valley tray will be in the wrong location. It shouldn't be too hard to make it work with a different valley pan but since I've never actually worked with that combination it's hard to offer any advice.
Dean it's too bad Summit/others did not tell you the truth about availability but that seems the norm anymore. Truth is, there are 4 of the 129's in Mopar warehouse stock, and if ordered one could be expected to show up quickly.
We were out of stock on 337s too for a short while but at the moment Mopar/Chrysler does have 3 of them on hand if someone wants to place an order.
Rich H.
Esse Quam Videri
Re: MP 4876129 manifold [Re: ZIPPY] #1470683
07/24/13 06:07 AM
07/24/13 06:07 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
ok, i know what direction i need to go on this one now, i already have a B indy Dominator manifold, i'll make spacers & my own vally plate & have it welded as a one piece. how thick are the spacers you get with the 440 manifolds to make them fit? they would be the same thickness yeah?
Re: MP 4876129 manifold [Re: rebel] #1470684
07/24/13 10:49 AM
07/24/13 10:49 AM
BradH Offline
BradH  Offline
MP RB Stage VI spacers are .850" thick, IIRC.
Dwayne Porter mounted mine to the heads w/ counter-sunk screws to keep them positioned properly while port-matching them to the heads' runners & intake manifold.
Re: MP 4876129 manifold [Re: BradH] #1470685
07/25/13 01:40 AM
07/25/13 01:40 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i looked on Mancinis' site. i can't find the spacer plates. anyone got a link or part # for these?
Re: MP 4876129 manifold [Re: rebel] #1470686
07/25/13 02:07 AM
07/25/13 02:07 AM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
I have a set of max wedge spacers that I will never use ( 383 block with 440 manifold ) if you want them or want me to measure them . PM me if interested
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: MP 4876129 manifold [Re: rebel] #1470687
07/26/13 05:58 PM
07/26/13 05:58 PM
AndyF Offline
AndyF  Offline
The Indy Mod Man intake might work for you. It is RB width and has a built in valley tray. You can order it with std ports or MW ports. It isn't a race manifold but it would work okay with a couple of small Edelbrock carbs.
