Quick lifter/valvetrain geometry question #1470325
07/19/13 04:55 PM
07/19/13 04:55 PM
USA
JoesMopar Offline OP
USA
Can I weld up a spare hydraulic lifter to check my geometry with rather than go out and buy a solid lifter? It would save me time and money. I'm going to use calipers to see how tall the lifters are in comparison anyway, but I thought it wouldn't be a big deal. Engine is a LA 360
Thoughts?
Re: Quick lifter/valvetrain geometry question [Re: JoesMopar] #1470326
07/19/13 05:58 PM
07/19/13 05:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Chances are the solid would not be the same height as the hydraulic lifter.
Re: Quick lifter/valvetrain geometry question [Re: JoesMopar] #1470327
07/19/13 06:00 PM
07/19/13 06:00 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
No need to weld. Just pull the cup and remove the spring from the botton and stack some washers or something comparable and solid and replace the cup. The cup should sit just below the snap ring groove. I keep a pair of old modified hydraulics around to check piston to valve clearance, coil bind and to determine the proper length for ordering pushrods.
Re: Quick lifter/valvetrain geometry question [Re: Stanton] #1470328
07/19/13 06:03 PM
07/19/13 06:03 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
The cup sits deeper in the body of a solid lifter and requires a longer pushrod.
Re: Quick lifter/valvetrain geometry question [Re: 5spdcuda] #1470329
07/19/13 11:26 PM
07/19/13 11:26 PM
What 5speed said. I measure preload then stack washers to locate the cup that same distance below the snap ring. I'm not sure if it needs to be that picky but that's how I do it
