Need copy of 8 3/4 clutch kit instructions! #147009
11/07/08 10:04 PM
11/07/08 10:04 PM
Emmett, Idaho
SuperStockWagon Offline OP
Emmett, Idaho
I bought the Mopar Performance sure-grip clutch plate rebuild kit for my 8 3/4 and it was missing the instruction sheet..does anybody know where I could down load the instructions?? I want to make sure I get the plates in correctly! Thanks! glckiss@msn.com
Re: Need copy of 8 3/4 clutch kit instructions! [Re: SuperStockWagon] #147010
11/07/08 10:39 PM
11/07/08 10:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Need copy of 8 3/4 clutch kit instructions! [Re: 1_WILD_RT] #147011
11/07/08 10:45 PM
11/07/08 10:45 PM
Emmett, Idaho
Emmett, Idaho
Thanks 1 Wild R/T..I searched for just such a thread,but obviously not well enough!
Re: Need copy of 8 3/4 clutch kit instructions! [Re: SuperStockWagon] #147012
11/07/08 10:49 PM
11/07/08 10:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I have that one saved...
Re: Need copy of 8 3/4 clutch kit instructions! [Re: 1_WILD_RT] #147013
11/07/08 11:23 PM
11/07/08 11:23 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I made an error when I originally posted that sequence. I had the dished plates/discs flipped around backward.
2 types of clutch packs are available. The "smooth" version includes dished plates, the "aggressive" version includes dished plates and dished discs.
Starting at the clutch hub:
1. Flat plate with ears
2. Flat disc
3. Dished plate with ears (ID facing away from clutch hub)
4. Flat disc or dished disc (ID facing away from clutch hub)
5. Thin flat plate with ears (OEM only) Repro power-locks use thick flat plate with ears
Prelube clutch pack with straight friction modifier. Torque case-half bolts to 50 lbs with red loc-tite.
Re: Need copy of 8 3/4 clutch kit instructions! [Re: DoctorDiff] #147014
11/07/08 11:32 PM
11/07/08 11:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thanks for the update!! I haven't put together the unit I saved the info for...
