wasn't the intake gaskets. #1470030
07/18/13 09:41 PM
07/18/13 09:41 PM
Q
Quicktree Offline OP
Q
changed the intake gaskets and was still pooling oil on the valves. looks like the oil sets in a pocket in the heads around the valve springs. the guides and seals must need replacing.
Re: wasn't the intake gaskets. [Re: Quicktree] #1470031
07/18/13 10:04 PM
07/18/13 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can drill and tap some external oil return lines
back to the pan
Re: wasn't the intake gaskets. [Re: MR_P_BODY] #1470032
07/18/13 10:15 PM
07/18/13 10:15 PM
Q
Q
guess you could but good guides and seal should take care of it. my other indy motor doesn't do that.
Re: wasn't the intake gaskets. [Re: Quicktree] #1470033
07/18/13 10:39 PM
07/18/13 10:39 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
from what I see you still have a gasket problem
Re: wasn't the intake gaskets. [Re: dodger mope] #1470034
07/18/13 10:45 PM
07/18/13 10:45 PM
Q
Q
please explain
Re: wasn't the intake gaskets. [Re: Quicktree] #1470035
07/18/13 11:09 PM
07/18/13 11:09 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
is that a home made gasket? I don't believe that much oil can get by the guides and seals unless there missing
Re: wasn't the intake gaskets. [Re: Quicktree] #1470036
07/18/13 11:23 PM
07/18/13 11:23 PM
Delray beach, Florida
P
Performance Only Offline
P
I see that sort of thing all the time. Seals are shot for sure and likely the guides as well. If it was all coming from the gaskets, it wouldn't be puddled on the valve like that since the engine would have to be running for the gasket to leak. Indy heads are particularly known for holding a lot of oil around the valve. that can be as good as it is bad. Oil cools the springs, so if the rest of the parts are good (guides and seals) it's not generally a problem.
machine shop owner and engine builder
Re: wasn't the intake gaskets. [Re: dodger mope] #1470037
07/18/13 11:32 PM
07/18/13 11:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The gasket pulls the most oil under vacuum and it will be burnt vs pooling up like that. Its definately the guides and or seals.
To me it looks likes the guides are wobbeling in the heads. The porting may of been to aggressive at the end of the guide on the aluminum part of the head that helps keep it steady. It appears in the pics that I see some seperations/gaps between the guide and the aluminum part of the guides stem. It loooks sloppy loose.
Re: wasn't the intake gaskets. [Re: Sport440] #1470038
07/19/13 02:25 AM
07/19/13 02:25 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I would remove a couple of intake springs and make sure the spring pocket is not in the port
Re: wasn't the intake gaskets. [Re: Performance Only] #1470039
07/19/13 06:40 AM
07/19/13 06:40 AM
Q
Q
believe me the gasket was sealed tight this time. this happens after the motor is shut down.
Re: wasn't the intake gaskets. [Re: Quicktree] #1470040
07/19/13 07:09 AM
07/19/13 07:09 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Unrelated issues but why is the adjuster on that intake valve flush and the others have lots of thread sticking out? unless that's a short rocker adjuster somethings not right. Also the rocker shaft hold-down stud by that same rocker is way to short. You really should have a full nut of thread engagement for proper strength.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: wasn't the intake gaskets. [Re: pittsburghracer] #1470041
07/19/13 07:18 AM
07/19/13 07:18 AM
PA.
"Little"John
"Little"John
PA.
As far as oil pooling around the springs on some of these heads the valve pockets are sunken way to deep and hold way to much oil around the spring. I take a small burr and grind drainage channels toward the the center of the engine to assist in draining off some of this oil. Its almost begging to be sucked down the guide. Keep in mind too that any rocker ratio greater than 1.5 on a Mopar leads to more rapid valve guide wear. What Indy head it that?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: wasn't the intake gaskets. [Re: pittsburghracer] #1470042
07/19/13 07:36 AM
07/19/13 07:36 AM
Q
Q
they are 360-1s, I was going to grind some groves to drain the oil better. the adjuster is the same as the rest it's just the angle of the pic.
Re: wasn't the intake gaskets. [Re: SB412DUSTER] #1470043
07/19/13 07:38 AM
07/19/13 07:38 AM
Q
Q
that will be checked also, but if were that bad it would be sucking air and running bad.
Re: wasn't the intake gaskets. [Re: Quicktree] #1470044
07/19/13 10:00 AM
07/19/13 10:00 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I didn't realize you had an oil pooling problem and have to agree with Dan on the valve seals.
Those Teflon seals you have on there have seen better days. Teflon has "amnesia", once stretched they do not return to their original shape. As the valve rocks in the guide it opens up the seal and makes the hole oblong. This allows a free pass of oil to the guide.
At this point I'd replace the seals. If you want I have a complete list on my website of 20 different Viton valve seals for any valve, guide, spring combination. Let me know if you need help with your selection
Re: wasn't the intake gaskets. [Re: Quicktree] #1470045
07/19/13 11:48 AM
07/19/13 11:48 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I've seen just a crack there that sucked in oil just like what you have
Re: wasn't the intake gaskets. [Re: SB412DUSTER] #1470046
07/19/13 12:45 PM
07/19/13 12:45 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
When it come to these heads check everything.
Re: wasn't the intake gaskets. [Re: MattW] #1470047
07/19/13 02:45 PM
07/19/13 02:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To me its just like Dan said... since it has oil puddling
when the engine is sitting there its dribbling down
past the valve seal and guides.. but it can be a crack
in the spring seat area.... on mine the intake valves
were dry so I think my issue was rings
Re: wasn't the intake gaskets. [Re: MR_P_BODY] #1470048
07/19/13 05:14 PM
07/19/13 05:14 PM
Q
Q
everything will be checked, but it would have to be on every valve they are all leaking.
Re: wasn't the intake gaskets. [Re: roadhazard] #1470049
07/19/13 05:15 PM
07/19/13 05:15 PM
Q
Q
thanks i'll keep that in mind
