Re: NeverWet Rust-Oleum
[Re: ScottSmith_Harms]
#1469896
07/18/13 07:12 PM
07/18/13 07:12 PM
Posts: 1,660 Cleveland, OH
TWS
Cleveland, OH
But on metal? I'm not sure its any better than a clear coat paint. It certainly has no rust prevention properties other than being hydrophobic.
There surely is some thickness involved...not clear how thick that may be. Sounds like the base coat is the key to the end thickness...top coat may be just the activator/catalyst (for lack of a better term). I didn't get the impression that it was a paint-like coating...the clothing applications as an example. I hadn't tried it myself, and am interested to see what others that have tried it thought. The manufacturer, at least, claims superior anti-corrosive properties to paint.
NeverWet Anti-corrosion
Product Characteristics
[Re: TWS]
#1469897
07/18/13 07:36 PM
07/18/13 07:36 PM
Posts: 2,304 WI
RestoRick
WI
Similar product- Ultra Ever Dry Downside I found in the specs is that it only lasts a couple months and would have to be reapplied. I don't know if the Rust-Oleum version is similar in that regard. Could be awesome for bare metal protection if it remains effective long enough.
[Re: THESHAKERPROJECT]
#1469901
07/19/13 02:22 PM
07/19/13 02:22 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, after some further research here's what I discovered: On "bare metal" applications or those that involve putting it on anything that has a specific color or finish, it will make it look frosted and adds a whitish/opaque color to the surface. It will change the "natural" appearance of most anything it is applied to, it's just less noticable on textured or multi-colored surfaces. Concerning the online demonstration, keep my above comments in mind and watch closely, you will see that they had the same results. Notice that every demonstration is done on white material to help mask this particular (residual) feature. Also watch the demonstration closely where the piece of glass has a square that has been treated on the outside of the perimeter. The treated area looks like it has been sand blasted because the NEVERWET leaves a white coloring when it is sprayed on the surface. It also left the same whitish coloring on the inside of the cardboard Box that was used as a beverage cooler. I'll post some before and after pics in the next few days with results on various substrates. Based on what I've learned to date RPM doesn't have to worry about being replaced by this product when it comes to an invisible barrier to oxidation on bare metal surfaces.
#1469904
07/19/13 06:50 PM
07/19/13 06:50 PM
TWS
Cleveland, OH
I'm not saying that its a bad product, I'm saying that from what I've seen its not a valid replacement for RPM when it comes to invisible metal protection against rust etc.
Case closed then.
