Strange S 60, How much gearlube?? #1469851
07/18/13 04:47 PM
07/18/13 04:47 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
I recently had a S 60 made from Strange engineering... ULTIMATE cover, 4;56 with a spool and Strange 35 spline axles.. The fill hole is almost at the TOP of the cover,, way ABOVE the top of the axle tubes.. i KNOW it doen't need THAT MUCH gearlube... ANY IDEAS????
Re: Strange S 60, How much gearlube?? [Re: nosboy] #1469852
07/18/13 05:36 PM
07/18/13 05:36 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I've run them as low as 2 quarts of 75W-90 synthetic gear lube but my last go round I put in 3 quarts.
Re: Strange S 60, How much gearlube?? [Re: nosboy] #1469853
07/18/13 05:39 PM
07/18/13 05:39 PM
maryland
74yellowduster Offline
maryland
street/highway or track?
highway you run it up to the filler hole
track only you can run a little less, like put your pinky in the drain hole if you can touch lube you are fine
check here, most everyone I know that races uses synthetic now
https://board.moparts.org/ubbthreads/showflat.php?Number=5737642
message doctordiff he knows all about differentials
Re: Strange S 60, How much gearlube?? [Re: nosboy] #1469854
07/18/13 07:44 PM
07/18/13 07:44 PM
Washington
SuperStock68Dart Offline
Washington
2 qts is plenty...I run 1.5 qts in my race Dana with that cover. Do not fill to the hole!!!
Re: Strange S 60, How much gearlube?? [Re: SuperStock68Dart] #1469855
07/19/13 07:06 AM
07/19/13 07:06 AM
pa
572charger Offline
572charger  Offline
pa
my factory dana 60 took 5 pints to come out of the filler hole after market covers have the hole real high if u have sealed axle bearings u don,t need as much stock axle bearings
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Strange S 60, How much gearlube?? [Re: SuperStock68Dart] #1469856
07/19/13 09:11 AM
07/19/13 09:11 AM
an8sec70cuda Offline
2 quarts is all you need, street or race.
CHIP
'06 GMC 2500HD LBZ Duramax
