GAS TANK SENDING UNIT ADJUSTMENT
#1469695
07/18/13 10:13 AM
07/18/13 10:13 AM
Posts: 43 Michigan
AnRT4Me
Re: GAS TANK SENDING UNIT ADJUSTMENT
[Re: dobie]
#1469699
07/18/13 11:59 AM
07/18/13 11:59 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I bought one for my '71 B body from Mancini and it works just fine.
Am I just lucky
Maybe. I've tried three now, from separate vendors and all have been WAY off. On a full tank the gauge reads 3/4, then drops quickly to "E" on a 1/2 or a bit more.
I'd be willing to spend the money (again) just to get one that works.
P.S. I see we're neighbors..
Yes neighbors we may just have to get together for a sometime
Well luck for you there is a shop in Akron called S U R & R on S. Main Street that specializes in fuel sending units. Bet if you take one over there they can get your unit figured out
[Re: dobie]
#1469701
07/18/13 01:04 PM
07/18/13 01:04 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Correct me if I am wrong, but if the float would go through it's full range of motion as the tank is filled it should read correctly? Ore is there more to it?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1469702
07/18/13 01:59 PM
07/18/13 01:59 PM
Posts: 343 S.E.Mich
drew72
S.E.Mich
You're correct. I guess some people don't know how to adjust (bend) the float arm. The gauge drops quickly after hitting 1/2 way because the float arm needs to be tweaked down a little bit. Some trial and error is sometimes needed, but they work in the end.
[Re: drew72]
#1469703
07/18/13 02:16 PM
07/18/13 02:16 PM
Posts: 1,032 Ohio
dobie
Ohio
Well, I've tried bending the arm in both directions. Still they've never been right.
1968 Plymouth Road Runner
383 4 speed
[Re: AnRT4Me]
#1469708
07/19/13 01:25 PM
07/19/13 01:25 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The sending unit should have 15 ohms resistance when full and 85 ohms when empty.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Pacnorthcuda]
#1469709
07/19/13 01:36 PM
07/19/13 01:36 PM
Posts: 5,891 Athens, Greece
Pyper70
Athens, Greece
I went through this one year ago...I bought the 3/8" after market sending unit. Reads fine OUT of the tank...but IN the tank the most the gauge shows is 1/2 full. I bent it every which way. I finally gave up. I bought the marine float adjustment from AutoMeter. Bought the matching fuel level gauge...Even though my gauge cluster was repaired perfectly (and I mean perfectly to the extent of paying close to a grand to restore). I have a functioning fuel gauge again as I retrofitted the faulty Chinese sending unit with the Autometer version. Works great now...I hid my extra gauge in the glove box as it's something you rarely look at
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pacnorthcuda]
#1469711
08/01/13 10:07 PM
08/01/13 10:07 PM
Posts: 5,439 So Cal
Sinitro
So Cal
One thing that can be done is an electronic 'fix'. If you're willing and able. First you isolate the gauge circuit from the instrument panel voltage regulator--this is the crude device that alternately turn the voltage for the instruments on and off so that the "AVERAGE" voltage fed to the gauges is approx 5V.
Crude is putting it nicely. You then build your own regulator with and SCR (silicon controlled recifier) and a few resistors--you can get the schematic on the internet. Part are cheap.
The really cool thing, is that you can use a variable SCR in the circuit that is adjustable. Hey! Right on! You can now calibrate your gauge lower or higher. But keep in mind--this adjustment will change the entire sweep of the gauge, so if it always reads high or low no matter if there is a little or a lot in the tank it will work. It will not fix a situation where its already accurate at some levels but not at others.
Now what happens to the calibration of the water temp and oil pressure guages...
Just my $0.02...
[Re: Sinitro]
#1469712
08/01/13 10:32 PM
08/01/13 10:32 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I bought the $60 sender from Van's Auto last year off of Ebay and it was spot on in and out of the tank. Proper reading for my car, I have been, told is 8-78 ohms and I measured 10-75 ohms on the bench. I mocked it up in the new tank I had and the arm was fine...no tweaking really to be done as far as bending it. Before this I had bought a cheap (then) repo for around 120$ around 2005 and it was off by a mile. It had a totally different resistance scale that went into the 100s of ohms. Granted this is a 1973 Charger but my gauge is pretty darn spot on now throughout the range down to 1/4 tank which is as low as I have gotten it before I get nervous and fill up. I have repro harnesses (stock) and re-done gauges through Instrument Specialties. I only have the little ground strap on the lines just like the factory. I guess I am one of the lucky ones?
[Re: Sinitro]
#1469713
08/01/13 10:53 PM
08/01/13 10:53 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Just my $0.02...
l
Re-read the part about isolating the gauge circuit. Do you think maybe that means isolating the circuit? I think it does. Yes my car has two instrument panel regulators, no reason you can't do that. You could put a separate one on EACH gauge if you want.
It's cool stuff.
[Re: Pacnorthcuda]
#1469714
08/02/13 11:05 PM
08/02/13 11:05 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Just my $0.02...
l
It's cool stuff.
Isolating the voltage limiter to one guage means that you have to cut up the PCB traces for that respective guage... Why not fix the sender issue correctly, toss that Chinese junker, get a good one and calibrate it..
Just my $0.02...
