SB Alternator Question #146922
11/07/08 06:13 PM
11/07/08 06:13 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
do small block alts have two grooves or one? I ask because I ordered one at the local NAPA with one groove. I will be using the V-belt system.
Re: SB Alternator Question [Re: sharpie] #146923
11/07/08 06:19 PM
11/07/08 06:19 PM
A/C uses 2, non A/C just 1 but you can slightly adj it's position with washers to make either one work.
Re: SB Alternator Question [Re: RapidRobert] #146924
11/07/08 06:22 PM
11/07/08 06:22 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
awesome, thanks! And you really are rapid with your response!
Re: SB Alternator Question [Re: sharpie] #146925
11/07/08 06:23 PM
11/07/08 06:23 PM
in more ways than one.
Re: SB Alternator Question [Re: RapidRobert] #146926
11/07/08 08:11 PM
11/07/08 08:11 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
'69 340 had one groove on the AC cars.
