suspension height. #1469154
07/17/13 11:14 AM
07/17/13 11:14 AM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Have a 1970 Challenger T/A. Can someone confirm what the ground to top of wheel well height is for both front and back?
Thanks in advance.
Re: suspension height. [Re: sailboat] #1469155
07/17/13 03:43 PM
07/17/13 03:43 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
The ride height should be set by measuring 2 points on the LCA. It's in the FSM.
Re: suspension height. [Re: Lefty] #1469156
07/17/13 07:55 PM
07/17/13 07:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I set mine lower then what the FSM said. My front end would have been WAY in the air. Use it as a guide though.
Re: suspension height. [Re: burdar] #1469157
07/17/13 11:15 PM
07/17/13 11:15 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Sorry. What is LCA and FSM?
Re: suspension height. [Re: sailboat] #1469158
07/17/13 11:41 PM
07/17/13 11:41 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
LCA = lower contol arm
FSM = factory service manual
Re: suspension height. [Re: sailboat] #1469159
07/17/13 11:42 PM
07/17/13 11:42 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
LCA=Lower Control Arm
FSM=Factory Service Manual
Re: suspension height. [Re: sailboat] #1469160
07/18/13 03:13 PM
07/18/13 03:13 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Due to variances in part dimensions, assembly tolerances, and tire sizes, the factory never specific a ground to fender lip height.
They did specify ride height by two measurements on the lower control arm, A - ground to lower ball joint and B - ground to t-bar socket. Subtract A from B and it should be around 1.125" difference. Although, I will admit, I do not have a '70 service manual to see if the TA/AAR specs are different from regular E body specs. I would think not since their rake was do to leaf spring and tire size differences.
