Battery is sizzling and about to explode #1469047
07/16/13 10:27 PM
07/16/13 10:27 PM
Tacoma, Washington USA
Adam71Charger Offline OP
bought a brand new battery for my 318. Works/starts great been using it for a month. recently, I noticed little specs of ruined paint in my engine bay, I thought it was brake fluid leaking from somewhere and splattering all around the engine bay.. turns out one of the vents/caps at the top of the battery is leaking, and the battery is all pushed out and looks like it's about to explode. I stopped at the parts store and they tested my battery. With the engine off, the battery was fulled charger. At engine idle, the battery was getting 14.24 volts and was 90 degrees, and they said the alternator was good. I noticed over the past few days that the needle in the alternator gauge in my dash goes way past the 'C' mark, like the battery is getting over charged. Does this sound like a battery problem or an alternator problem?
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469048
07/16/13 10:36 PM
07/16/13 10:36 PM
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469049
07/16/13 10:40 PM
07/16/13 10:40 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
voltage regulator problem..it happened to me..
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469050
07/16/13 10:40 PM
07/16/13 10:40 PM
pennsylvania
poboyengineering Offline
pennsylvania
put a voltmeter on it..im betting the alternator is charging at 14.5+ volts.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Battery is sizzling and about to explode [Re: poboyengineering] #1469051
07/16/13 10:51 PM
07/16/13 10:51 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
I just had. an overcharged problem. The regulator wasn't ground well. I cleaned up the all the parts and screwed it back on
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469052
07/16/13 11:01 PM
07/16/13 11:01 PM
As said bad reg or no reg ground. Less likely would be a grounded "green" field wire or alt field is grounded on the green wire side (brush assy). ASAP! pull the connector off of the reg till you get it solved. Deepcycling the batt by letting it run down with no charging is FAR less damaging than driving it with it full fielded like it is right now. That'll cook the batt/damage wiring & terminals/stress bulbs & accessories that are on as they ain't designed for 15+ volts
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469053
07/16/13 11:04 PM
07/16/13 11:04 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
sounds like a classic bad voltage regulator
Re: Battery is sizzling and about to explode [Re: RangerDan440] #1469054
07/16/13 11:16 PM
07/16/13 11:16 PM
where is the voltage regulator and what does it look like?
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469055
07/16/13 11:19 PM
07/16/13 11:19 PM
ok I just looked at a picture, Ill track it down
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469056
07/16/13 11:36 PM
07/16/13 11:36 PM
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469057
07/16/13 11:37 PM
07/16/13 11:37 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Might be the battery, if the volts are under 14.6v warm at say 2500 rpm the charging system is fine.
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469058
07/17/13 02:11 AM
07/17/13 02:11 AM
IMGTX Offline
IMGTX  Offline
Replace the Voltage regulator as a start.
Do not drive it with the charging pegged to the C. The wiring in these old cars won't handle high current and when the alternator is putting out the max it has the same effect as a shorted wire. Too much current flow is too much current flow. I had to rewire my Satellite because of a bad VR that I ignored for too long.
Re: Battery is sizzling and about to explode [Re: IMGTX] #1469059
07/17/13 03:16 AM
07/17/13 03:16 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
You say they tested the voltage at the battery at idle and it was at 14.25v? If so, that voltage is fine...
15v+ would cause your problem. 14.5v is ideal charging voltage, so your problem may be the battery. Unless something else goofy is going on
Re: Battery is sizzling and about to explode [Re: hooziewhatsit] #1469060
07/17/13 06:25 AM
07/17/13 06:25 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
these alternators are not very good. if you have 14.5 volts at idle...what kind of voltage is it putting out when you have say 2500 RPM?!
**Photobucket sucks**
Re: Battery is sizzling and about to explode [Re: 70Cuda383] #1469061
07/17/13 08:12 AM
07/17/13 08:12 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
As others have said, test your voltage at higher RPM. It's possible a bad battery could cause your ammeter to read "charge".
It's Swifty! Swifty, you toad sucker!
Re: Battery is sizzling and about to explode [Re: zrxkawboy] #1469062
07/17/13 10:21 AM
07/17/13 10:21 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Just to throw one more thing into the mix
Some time ago I put a new alternator on my Charger and the lead wire stud rotated in the alternator causing a direct internal ground
Had the exact same symptoms as you describe so if the voltage regulator does not cure your problem or you have messed with the alternator recently it's another place to look. You can test it with an ohm meter from the lead wire stud to the case.
Re: Battery is sizzling and about to explode [Re: roadhazard] #1469063
07/17/13 10:22 PM
07/17/13 10:22 PM
Ok so began by replacing the voltage regulator, and making sure the the ground was metal to metal on both sides. Using my FSM engine wiring diagram I went over all the associated wires and made sure they were hooked up right, and replaced/repaired all bad connections, it was a mess in there hidden by electrical tape. About to start it up, but I noticed my choke wire isnt hooked up. It needs 12V when the engine is on, should I hook it to the power side of the ballast resistor?
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469064
07/17/13 10:28 PM
07/17/13 10:28 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Yes that will work. The factory used the blue field wire (same circuit anyway) going to the alternator/from VR but both should get battery voltage when the key is in the 'run' position.
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469065
07/17/13 10:31 PM
07/17/13 10:31 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
I would go and get a new engine harness, if the funds are available. It looks like the factory wrap was replaced with scotch 33 after some 'investigating'. There seems to be poor connections and radio shack crimps to try and get by, but I'd recommend a new harness after looking at your pictures.
Re: Battery is sizzling and about to explode [Re: Adam71Charger] #1469066
07/18/13 12:37 AM
07/18/13 12:37 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
My best guess: battery has a shorted cell. In the old days (removable caps), this was easy to test, but not any more.
If I'm right, you are now effectively charging a 10-volt battery at 14.5 V (prox). Current goes sky-high, battery explodes. Not fun.
Rick
