Piston question #146852
11/07/08 03:56 PM
11/07/08 03:56 PM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
I just bought a set of used 440 pistons : TRW L2266 .030 over. The seller didn't disclose that one of the pistons looks like something nasty fell into the cylinder. It has a lot of pock marks and 2 gouges about 1/16 that have burrs. Is this piston usable, can it be reconditioned, and if not can I still purchase on of these?
Re: Piston question [Re: whitemtnelf] #146853
11/07/08 04:22 PM
11/07/08 04:22 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
What does the seller say NOW about the undisclosed damage? Is this damage just on the top ?
Re: Piston question [Re: whitemtnelf] #146854
11/07/08 06:50 PM
11/07/08 06:50 PM
post a(closeup) pic if the damage
Re: Piston question [Re: RapidRobert] #146855
11/07/08 07:08 PM
11/07/08 07:08 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If it's that bad you could always buy ONE new piston. Probably about 45 bucks for a piston like that if it's not salvageable. I agree, he should have disclosed.
I've always wondered about used pistons, are they safe to use? I can see ones used with floating pins being okay for reuse, but what about ones used w/ pressed pins? With the heat that area is under then the pin is pressed in the rod and all...
Re: Piston question [Re: DaytonaTurbo] #146856
11/07/08 07:16 PM
11/07/08 07:16 PM
myself I would not be comfortable with used pistons but I see them regularly for sale. The machine shop has to have the fixture that goes in & supports the bottom side of the rod small end other wise the bottom of the piston would likely be damaged when pressing the pin with everything bearing down on the bottom( the side actually) of the piston
Re: Piston question [Re: dOoC] #146857
11/07/08 08:43 PM
11/07/08 08:43 PM
New Hampshire
W
W
New Hampshire
I'll get a pic up tomorrow. The damage is only on the top. I'm waiting to hear back from the seller.
Re: Piston question [Re: whitemtnelf] #146858
11/08/08 12:56 AM
11/08/08 12:56 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you are prob safe as i have used those pistons and they are a very strong forging and are app 1/2 in thick in the tops.
just check that the damage hasent caused a tight top ring land , if it has you can recondition it .
Re: Piston question [Re: calrobb2000] #146859
11/09/08 12:32 PM
11/09/08 12:32 PM
dogdays Offline
dogdays  Offline
They are Speed-Pro forgings, weigh a ton and I'd measure the dinged-up one and use it if there was no noticeable distortion at the piston crown diameter.
Or go to any parts store or Summit/Jegs and buy a single, they're still in production.
This is my place to say they weigh a ton and there are better pistons out there from a weight point of view. But since you have them go for it.
R.
