Distributor Question? #1468222
07/15/13 01:18 PM
07/15/13 01:18 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Just wondering if anyone has ever used the J685 limiter disc that limits the mech. advance in electronic dists. from 4seconds flat? If so how good is it? It appears to be better than welding up the slots. Although I do need more than 18 degrees mech. which is the max. limit it will go. Thanks, Dave.
Re: Distributor Question? [Re: superbeedave] #1468223
07/15/13 09:19 PM
07/15/13 09:19 PM
I ain't used it myself or even seen one but it sounds like a good idea. What about fabbing your own since his dont have enough advance. I am going to drill a mini hole in each outer end of the cam slot & use a setscrew to limit the travel of the pins then access it thru the vac adv window to make "total" adjustments without having to take out the center clip/file the welded slots but I just ain't got around to it yet. Holler how it goes for you
Re: Distributor Question? [Re: superbeedave] #1468224
07/16/13 11:36 AM
07/16/13 11:36 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I have one. It works great! I just needed 14 degrees mechanical. You could open the slots up some if you need more than 18 degrees.
Re: Distributor Question? [Re: torkrules] #1468225
07/16/13 11:52 AM
07/16/13 11:52 AM
Cincinnati, Ohio
Cincinnati, Ohio
Finally someone that has one of these disc. That's exactly what I was thinking. Open up a pair of the slots that I will probably never use to about 20-22 degrees. I have been sitting here for an hour debating on call them up and purchasing this disc. I am quessing this goes in between the slots and the weights. It looks simple and easy to install and to me it takes place of welding or jb welding the slots up. So what is this disc made out of and how thick is it? I'm quessing it is approx. .050-.060 thick steel or maybe aluminum. It shouldn't be too hard to make one if you had a few dims. of the disc to go with. It's just symetrical so that makes it easier. Thanks, Dave
