3.23 ring and pinion #1468182
07/15/13 12:02 PM
07/15/13 12:02 PM
Ball Ground GA
TrueTripleX Online content OP
TrueTripleX  Online Content OP
Ball Ground GA
Like many of you, I am trying to find a 3.23 set up for a 489 case and NO ONE seems to have one. What is everyone else doing to get around this? Are there any manufacturers/suppliers that you would NOT recommend going to (due to noise, wear issues, etc.)? What are your thoughts on USED units? And does anyone have the part number for this assembly? I don't want to get a 3.23 for a 741/742 case
Re: 3.23 ring and pinion [Re: TrueTripleX] #1468183
07/15/13 12:05 PM
07/15/13 12:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
edit ... looky looky ...
Re: 3.23 ring and pinion [Re: TrueTripleX] #1468184
07/15/13 12:34 PM
07/15/13 12:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nitro Gear has new 3.23 R&P's for the 489.
http://www.nitro-gear.com/ring-pinions/
Re: 3.23 ring and pinion [Re: John_Kunkel] #1468185
07/15/13 12:36 PM
07/15/13 12:36 PM
Ball Ground GA
Ball Ground GA
Thanks John. Have you tried the Nitro's? I had heard that they are noisy?
Re: 3.23 ring and pinion [Re: TrueTripleX] #1468186
07/15/13 12:42 PM
07/15/13 12:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't think there's any brand that's consistently noisy; if they were they couldn't sell them so it's a crap shoot with any of them.
Re: 3.23 ring and pinion [Re: John_Kunkel] #1468187
07/15/13 12:46 PM
07/15/13 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have seen where Richmond gets accused of being noisy from time to time and that doesn't seem to hurt them ?
Re: 3.23 ring and pinion [Re: JohnRR] #1468188
07/15/13 02:03 PM
07/15/13 02:03 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
If you are running 4.30s in a drag car gear noise is NBD. If your 3.23s whine on the freeway so bad you want to stick an icepick through your ears to stop the pain, probably a Big Deal. Intended usage and when the gears make noise is the issue, though correct setup is the key to minimizing it.
Re: 3.23 ring and pinion [Re: John_Kunkel] #1468189
07/15/13 07:51 PM
07/15/13 07:51 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If Nitro/JT has a 3.23 489 gear in stock (which I doubt), it is NOS.
They do source an aftermarket 3.23 742 ring and pinion, however.
Re: 3.23 ring and pinion [Re: TrueTripleX] #1468190
07/15/13 08:39 PM
07/15/13 08:39 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Try DTS...
Drivetrain Service...
