Hemi distributor # #146788
11/07/08 11:56 AM
11/07/08 11:56 AM
CENTRAL MINN
1965_PLYMOUTH Offline OP
CENTRAL MINN
I'm looking at this 426 Hemi distributor. part #2875327 the number doesn't come up in any books I have. he says it's a 1968 optional distributor. anybody ever see this number before?
Re: Hemi distributor # [Re: 1965_PLYMOUTH] #146789
11/07/08 12:14 PM
11/07/08 12:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
There's no such thing as a 1968 "Optional" distributor. He's probably got an over the counter race or replacement piece he's trying to sell, they are pretty common.
Re: Hemi distributor # [Re: ScottSmith_Harms] #146790
11/07/08 12:28 PM
11/07/08 12:28 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I think he's looking at Galen's white book. It lists a:
'SPECIAL ORDER PARTS 2875255/ "LESS CAP & ROTOR" 2875327/ IBB-4401A 1968 426 HEMI BOTH (manual and automatic) A (body) TACH DR'
I've tried to accurately reproduce the listing but the original is a little jumbled.
Re: Hemi distributor # [Re: 6PakBee] #146791
11/07/08 12:31 PM
11/07/08 12:31 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
Its prob a tach drive "race'" unit
very common and cheap
Re: Hemi distributor # [Re: HemiGreg] #146792
11/07/08 01:37 PM
11/07/08 01:37 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the one he is asking about isn't cheap though
Re: Hemi distributor # [Re: JohnRR] #146793
11/07/08 02:42 PM
11/07/08 02:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you can fund the transistor ignition control that goes with it they work real well,if not still works good.
Re: Hemi distributor # [Re: 62maxwgn] #146794
11/07/08 02:50 PM
11/07/08 02:50 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Looks like a tack drive distributor for a 1968 super stock Dart or Baracuda to me.
Getting old just means you were smarter than some and luckier than others.
Re: Hemi distributor # [Re: dannysbee] #146795
11/07/08 06:01 PM
11/07/08 06:01 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Re: Hemi distributor # [Re: 62maxwgn] #146796
11/07/08 08:38 PM
11/07/08 08:38 PM
CENTRAL MINN
CENTRAL MINN
SPECIAL 2875255/ """LESS CAP & ROTOR"""
ORDER 2875327/
PARTS IBB-4401A D 1968 426 HEMI BOTH A TACH DR
this how it's advertised.
Re: Hemi distributor # [Re: 1965_PLYMOUTH] #146797
11/08/08 09:29 AM
11/08/08 09:29 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Hope you can read it.
Re: Hemi distributor # [Re: 62maxwgn] #146798
11/08/08 12:37 PM
11/08/08 12:37 PM
Kent, WA
triple_green Offline
Kent, WA
So was the hemi distributor the same as the rest of the big blocks?
I've got the one that supposedly came with my 69 hemi...but I was told it was probably not unique from other big block distributors.
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Hemi distributor # [Re: triple_green] #146799
11/08/08 03:26 PM
11/08/08 03:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thanks!
Actually,the only thing that makes it unique is the tag."If it is the original tag"
Re: Hemi distributor # [Re: 62maxwgn] #146800
11/08/08 03:38 PM
11/08/08 03:38 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The vacuum advance unit and the centrifugal advance are both different and have unique stamped numbers on them.
Re: Hemi distributor # [Re: Snoopy] #146801
11/08/08 03:59 PM
11/08/08 03:59 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
But,thats easy to change.
Original 70 Hemi on left,69 1/2 on right.
Re: Hemi distributor # [Re: 62maxwgn] #146802
11/08/08 04:07 PM
11/08/08 04:07 PM
Snoopy Offline
Snoopy  Offline
The mechanical advance unit would require one from a real Hemi distributor or an NOS Hemi part.
Re: Hemi distributor # [Re: Snoopy] #146803
11/08/08 04:10 PM
11/08/08 04:10 PM
Snoopy Offline
Snoopy  Offline
Bill,
When did they change from a metal seal to an o-ring on the distributor housing?
Re: Hemi distributor # [Re: Snoopy] #146804
11/08/08 04:18 PM
11/08/08 04:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Pretty sure it was 68,but I've been wrong before!
Re: Hemi distributor # [Re: 62maxwgn] #146805
11/08/08 09:27 PM
11/08/08 09:27 PM
Kent, WA
Kent, WA
what does the tag say on it?
Re: Hemi distributor # [Re: triple_green] #146806
11/10/08 02:21 PM
11/10/08 02:21 PM
HemiGreg Offline
HemiGreg  Offline
Re: Hemi distributor # [Re: triple_green] #146807
01/12/09 10:07 PM
01/12/09 10:07 PM
CENTRAL MINN
CENTRAL MINN
sorry to revive this post after 2 months. does anybody have the listing for certain part numbers associated with 426 HEMI only motors? like, I have a dual point here with the numbers IBS4006 2642482 I want to say it comes from a 67 GTX that bit the bullet 30 years back. does anybody out there know for sure? thank's; Greg
