Re: Hemi distributor #
[Re: ScottSmith_Harms]
#146790
11/07/08 12:28 PM
11/07/08 12:28 PM
Posts: 10,757 North Dakota
6PakBee
North Dakota
I think he's looking at Galen's white book. It lists a:
'SPECIAL ORDER PARTS 2875255/ "LESS CAP & ROTOR" 2875327/ IBB-4401A 1968 426 HEMI BOTH (manual and automatic) A (body) TACH DR'
I've tried to accurately reproduce the listing but the original is a little jumbled.
[Re: JohnRR]
#146793
11/07/08 02:42 PM
11/07/08 02:42 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Its prob a tach drive "race'" unit very common and cheap
the one he is asking about isn't cheap though
If you can fund the transistor ignition control that goes with it they work real well,if not still works good.
[Re: 62maxwgn]
#146798
11/08/08 12:37 PM
11/08/08 12:37 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
So was the hemi distributor the same as the rest of the big blocks?
I've got the one that supposedly came with my 69 hemi...but I was told it was probably not unique from other big block distributors.
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
[Re: triple_green]
#146799
11/08/08 03:26 PM
11/08/08 03:26 PM
62maxwgn
Blair County,PA
Thanks!
Actually,the only thing that makes it unique is the tag."If it is the original tag"
[Re: 62maxwgn]
#146800
11/08/08 03:38 PM
11/08/08 03:38 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
The vacuum advance unit and the centrifugal advance are both different and have unique stamped numbers on them.
[Re: Snoopy]
#146801
11/08/08 03:59 PM
11/08/08 03:59 PM
62maxwgn
Blair County,PA
But,thats easy to change.
Original 70 Hemi on left,69 1/2 on right.
[Re: 62maxwgn]
#146805
11/08/08 09:27 PM
11/08/08 09:27 PM
triple_green
Kent, WA
what does the tag say on it?
