Re: Tired of sweating my bees off
[Re: moparcanuk]
#1467960
07/15/13 09:55 AM
07/15/13 09:55 AM
Posts: 75,017 U.S.S.A.
JohnRR
U.S.S.A.
We are sweltering in 100 degree heat and I'd really like to install A/C in my 69 GTX. I've asked about the aftermarket products but am not convinced. Is there a later Mopar A/C unit that would fit? Perhaps from the 80s or 90s?
Later a/c unit , what part ? the compressor or ALL of it ???
[Re: moparcanuk]
#1467961
07/15/13 02:34 PM
07/15/13 02:34 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Someone posted about a newer style set up, like the places that sell aftermarket air sell, but for a lot less $. Although a parts listed was never mentioned. I've never like ac, but I'm thinking with a black car it may have to go back in. I had this same thought about what ac box to use and so on earlier today.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: YYZ]
#1467963
07/15/13 02:45 PM
07/15/13 02:45 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
What about a Mopar underdash unit, powered by a later model Sanden (rotary) compressor?
The rotary compressors can be mounted in such a way that they don't interfere
It's nice to ride in a Superbird with the A/C on...
[Re: RSNOMO]
#1467964
07/15/13 09:17 PM
07/15/13 09:17 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Not one answer so far to the OP's original question...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1467969
07/16/13 08:59 AM
07/16/13 08:59 AM
JohnRR
U.S.S.A.
Because the question is so vague it's impossible to answer ...
[Re: Gabmando]
#1467970
07/16/13 09:02 AM
07/16/13 09:02 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I'd use Classic Auto Air. They have the aftermarket HVAC boxes, rotary compressors, brackets, etc. I used their Sanden compressor kit and had them make custom lines for my 1973 Charger and they were extremely helpful. I talked to the support guy, Ron and he knew his stuff. I'd call him when I was at my local A/C shop getting the fittings installed with a question or needing a part and he'd always answer (phone or email) and have whatever I needed shipped out the next day. If you car was non-A/C originally, then yes the firewall is different so you would have to drill new holes and weld up others as already stated. Since you are looking at some mods to the car anyway, I vote getting the aftermarket box and going with a rotary compressor. BPE sells them but Classic Auto Air does as well and they are cheaper and will have everything you need. I think they even have some 'perfect fit' systems for your car which supposedly drop right in (at least to an original A/C car). You will probably have to add vents to your dash if it was a non-A/C car. Aftermarket systems will also most likely use electric servos to open/close the air doors inside which is worlds better than the original vacuum actuators. If you have an engine with lower vacuum or hit he brakes really hard, you will have the doors returning to their resting positions momentarily with the old actuators. The newer electric servos don't have this issue.
[Re: cjskotni]
#1467972
07/17/13 12:34 AM
07/17/13 12:34 AM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
Thanks for the info.
