rebuilding a /6 manual steering box
#1467489
07/14/13 02:43 AM
07/14/13 02:43 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The steering box in the hot rod appears to be the source of the front end vibrations. It's a manual box from a slant six 1964 Belvedere. It's my understanding that most slant six boxes had bushings instead of bearings. Is this true? If so, can they be replaced or converted to bearings?
I've adjusted the box a few times over the last 15 years and the screw is bottomed out. There is still slop in the box. I still get a hard vibration in the steering wheel that goes away when the car is turning. The rest of the front end and steering components are tight.
Re: rebuilding a /6 manual steering box
[Re: feets]
#1467491
07/14/13 09:16 AM
07/14/13 09:16 AM
RapidRobert
Since the box will be coming out is there a possibility you could sub in another box to confirm that that was it before you go to the trouble of rebuilding the /6 box
[Re: RapidRobert]
#1467492
07/14/13 11:48 AM
07/14/13 11:48 AM
feets
Senior Management
Senior Management
Irving, TX
The box is the problem. I can't take out any more slack. The pitman arm is rattling back and forth against the steering input shaft as the car goes down the road.
If I had a cheap manual steering box available I would not entertain the thought of rebuilding this box. Those things are not exactly common at the junk yards.
This car will be going up for sale. I've already sunk a bunch of time and money in it. If someone were to be so kind as to drop a new steering box in my lap I'd gratefully install it in the car.
Can you replace the bushings inside a slant six box with bearings?
[Re: 5spdcuda]
#1467497
07/15/13 12:03 AM
07/15/13 12:03 AM
feets
Senior Management
Senior Management
Irving, TX
I was planning on going through the steering box. If I do that, I'd rather replace the bushing with bearings. There is a problem in the box and I need to find out what it is.
I do appreciate the bearing part numbers.
My concern with buying a used box is that mine is a used box and there's no guarantee that I'd get anything better than what I've already got.
[Re: feets]
#1467498
07/15/13 11:33 PM
07/15/13 11:33 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
While this is no guarantee that a junkyard box will be any better, I should just mention that C-body / B-van boxes are beefier and will bolt in (w/ large spline pitman). (Larger case can cause some clearance issues with some headers). Rick
