Wiper motors - 2 speed -VS- 3 speed? (68 Charger) #1467434
07/13/13 08:50 PM
07/13/13 08:50 PM
Santa Cruz, California
Lefty Offline OP
Lefty  Offline OP
I need a 3 speed wiper motor and dash switch for 68 Charger.
All I see are 2 speed (Cardone) motors and 2 speed switches (eBay-stupid expensive)
Am I doomed to on/off wiper speeds?
Did Chrysler really make 2 different motors for 2 and 3 speed wipers?
Can you point me to a good vendor for these parts?
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: Lefty] #1467435
07/13/13 09:12 PM
07/13/13 09:12 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The 2-spd wipers were STANDARD for the '68 Charger, 3-spd wipers were OPTIONAL (Req'd w/426 HEMI).
the 2-spd switch has 3 positions: OFF-LOW-HIGH
the 3-spd switch has 4 positions: OFF-LOW-MEDIUM-HIGH
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: 6bblgt] #1467436
07/13/13 09:51 PM
07/13/13 09:51 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: 6bblgt] #1467437
07/13/13 11:48 PM
07/13/13 11:48 PM
Lefty Offline OP
Lefty  Offline OP
Hmm... I read 2 speed was off-on and 3 speed was off-low-high. Waddya know, bad info off the Internet...
Thanks for setting me straight.
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: Lefty] #1467438
07/14/13 12:16 AM
07/14/13 12:16 AM
california
Mr D21 Offline
Mr D21  Offline
california
off is not a speed...
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: Mr D21] #1467439
07/14/13 12:42 AM
07/14/13 12:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Isn't off actually reverse for parking? So technically speaking, when in reverse it does have a certain speed until it quits. Ha! as the Car Guys say. You've wasted a perfectly good hour...
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: kentj340] #1467440
07/14/13 10:49 PM
07/14/13 10:49 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So is it just the switch that makes the multiple speeds? or do you need a motor to match the switch also?
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: rowin4] #1467441
07/14/13 11:07 PM
07/14/13 11:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
for the 68-70 B body, to convert from 2 spd wipers, you need the correct 3 spd wiper motor and 3 spd switch, the underdash harness already has provisions for the 3spd switch, kinda plug and play...
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: DAYCLONA] #1467442
07/15/13 11:09 AM
07/15/13 11:09 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Good question.
On the two-speed motor assembly there is a resistor block (looks like a balast resistor) that slows the motor down. The dash switch sends power through the resistor on low speed or direct to the the motor on high.
On the three-speed motor the speed is controlled by the windings on the motor and the switch sends power directly to the appropriate winding for the selected speed.
To convert to three-speed you need the following:
3-speed motor
3-speed switch
3 speed wiper link/arm and bushing
"I think" you need to add a connector to the harness since the 2-speed has terminals on the motor and the 3-speed motor has a harness.
Re: Wiper motors - 2 speed -VS- 3 speed? (68 Charger) [Re: Stanton] #1467443
07/17/13 07:10 PM
07/17/13 07:10 PM
super gas
super gas
This is all you need. No extra connectors or mods.
https://board.moparts.org/ubbthreads/show...e=1#Post6177485
Jules
