Anyone use lowering blocks? #1467326
07/13/13 05:14 PM
07/13/13 05:14 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I am thinking of putting the rear down some..are the aluminum ones ok? Ive seen cast aluminum and billet alum and steel. Any recommendations? Does it affect 60 ft times negatively? Pinion angle? .. might need the 2 inch, but possibly 1's. Thanks in advance..
Re: Anyone use lowering blocks? [Re: Hot 340] #1467327
07/13/13 05:59 PM
07/13/13 05:59 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I use 1-1/2" lowering blocks on my Dart. I went from a 29.5 tyre to a 31 and it started handling badly, so i fitted the blocks it dropped the rear end and was fine again. Use the billet ones though, not the cheap ones.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Anyone use lowering blocks? [Re: Hot 340] #1467328
07/13/13 06:08 PM
07/13/13 06:08 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I'm using billet blocks on mine.
I used them to lower it AND improve the 60' by changing the pinion angle by milling them to the specified angle I wanted.
Re: Anyone use lowering blocks? [Re: Duner] #1467329
07/13/13 06:15 PM
07/13/13 06:15 PM
west palm beach, florida
modelmakerinc Online content
modelmakerinc  Online Content
I have them on the Fury, I needed to get the stance right with superstock springs and 31" tires
find your local 4x4 shop they will get you the steel blocks square or tapered, u-bolts and *shims
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Anyone use lowering blocks? [Re: Hot 340] #1467330
07/13/13 08:04 PM
07/13/13 08:04 PM
Az
Crizila Offline
Crizila  Offline
Az
I run 1" aluminum blocks from Caltracs with no problems ( their springs, perches, spring clamps ). Change to pinion angle is negligible.
Fastest 300
Re: Anyone use lowering blocks? [Re: Hot 340] #1467331
07/13/13 09:18 PM
07/13/13 09:18 PM
Redding,CA USA
440charger500 Offline
Redding,CA USA
I use the ones from speedway motors
Re: Anyone use lowering blocks? [Re: 440charger500] #1467332
07/14/13 12:12 AM
07/14/13 12:12 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I think cast iron would be acceptable, but prefer billet aluminum or steel.
DO NOT USE CAST ALUMINUM!!! I've read many internet reports of them crumbling to dust over time.
I have cast iron blocks on my truck now, but only been on there a year, so no real long term longevity reports yet, but I can say that the truck handles fine...about the same as without the blocks.
**Photobucket sucks**
Re: Anyone use lowering blocks? [Re: Hot 340] #1467333
07/14/13 03:12 AM
07/14/13 03:12 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I would use some decent aluminium or steel ones. Make sure you regularly check your U bolts as they will tend to work loose.
Alan Jones
Re: Anyone use lowering blocks? [Re: Hot 340] #1467334
07/14/13 08:23 AM
07/14/13 08:23 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
My recommendation is to lower the rear using the hangers with the extra holes sold by companies like firm feel.
Leaf Spring Hangers
"to fit leaf springs with 20" or 22" front segments in your B-body."
From the website: These hangers are HD reproductions of the OEM hanger with the addition of an extra upper eyebolt hole so the car can be lowered 1.5 inches. The hangers are made from 0.188 steel, zinc plated for corrosion resistance and come complete with the OEM style hanger studs already pressed into place. Use the lower eyebolt hole location for stock ride height
I have news for you...
Lowering blocks are a compromise.
Going fast is dangerous and people get killed from hardware failures and bad choices. Try to make good choices.
From someone who does goes very fast doing road course 3.4 mile long hot laps for 45 minutes at time vs 1320 feet @ 10 seconds at a time.
Re: Anyone use lowering blocks? [Re: Duner] #1467335
07/14/13 03:29 PM
07/14/13 03:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
THIS...............
Re: Anyone use lowering blocks? [Re: Thumperdart] #1467336
07/14/13 04:04 PM
07/14/13 04:04 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use 1" ones on my S-10 with caltracs
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Anyone use lowering blocks? [Re: bigtimeauto] #1467337
07/14/13 04:42 PM
07/14/13 04:42 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks guys, makes me feel more at ease using them... billet alum or steel they will be. Thanks for the heads up on the cast ones too...
Re: Anyone use lowering blocks? [Re: ThermoQuad] #1467338
07/14/13 04:45 PM
07/14/13 04:45 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Leaf Spring Hangers
Tom, im gonna need blocks even after the lowering of the front hanger...
