Rusty rocker arms, pushrods, rocker shafts... #1467149
07/13/13 01:06 AM
07/13/13 01:06 AM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
Pulled this engine apart. Has rusty rocker arms, pushrods, rocker shafts, and heads.
What would cause this? Other than a sloppy chain, motor seems solid. I pulled the intake, and its like new there. Just the top of the head/rockers are RUSTY. Under the valve covers is also rusty.
Head gaskets maybe? But why just the top end rusty? Wouldn't the valley be rusted out too?
Motor is a 1976 360. Picked it up to replace the 318 for now until the other 360 is done. 318 finally said kafrigginboom.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467150
07/13/13 01:52 AM
07/13/13 01:52 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The rust is probably from condensation and the possibility that the engine was ran cold too often.
I have had engines that had steam type vapor come from the breather until the engine warmed up.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: Kern Dog] #1467151
07/13/13 03:17 AM
07/13/13 03:17 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: 340SHORTY] #1467152
07/13/13 04:11 AM
07/13/13 04:11 AM
woodcrest, CA
woodcrest, CA
Next question.
I have an "extra set" of rockers and shafts, and rods. If I replaced just the rusty stuff, would it be "ok"?
Not looking to spend too much money on this motor. Just a temporary replacement, and any money spent on it takes away from the good 360 build.
Pics coming soon. Just got too late and dark.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467153
07/13/13 04:50 AM
07/13/13 04:50 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Seems to me that once the oil gets up to temp it will absorb the moisture still present. The rust may dissolve in the oil if it has a high detergent package to it. I'd probably be diligent about oil and fliter changes though.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: Kern Dog] #1467154
07/13/13 08:13 AM
07/13/13 08:13 AM
scratchnfotraction Offline
just swap out the shafts/rockers/push rods any springs or retainers that might be rusted up. (318 parts will fit)
clean the rust from the head with a wire brush and shop vac as you brush the rust loose.
just make sure your shafts are on the correct way for each head and the offset is correct on each rocker as they slide on the shaft.
you dont want any loose rust floating around in there when it goes back into srevice.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: scratchnfotraction] #1467155
07/13/13 10:29 AM
07/13/13 10:29 AM
woodcrest, CA
woodcrest, CA
Thanks Mike. That sounds promising. I have a set of stock rockers that are zinc(?) plated from a 79 360 that I can throw in there. Also have a set of steel shim head gaskets I bought that I can't use since I'm going with aluminum heads on the other motor. Looks like these heads are coming off, and getting cleaned up. I'd feel better knowing it had new head gaskets anyway.
Thanks for the help guys
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467156
07/13/13 02:30 PM
07/13/13 02:30 PM
woodcrest, CA
woodcrest, CA
Passenger side
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467157
07/13/13 02:32 PM
07/13/13 02:32 PM
woodcrest, CA
woodcrest, CA
Another passenger side
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467158
07/13/13 02:37 PM
07/13/13 02:37 PM
woodcrest, CA
woodcrest, CA
Drivers side
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467159
07/13/13 02:50 PM
07/13/13 02:50 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I tore down a /6 that had similar issues top end rust wise. Turned out it was the head gasket.
Sounds like ya are on the right path!
Keep
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: old_goat] #1467160
07/13/13 03:48 PM
07/13/13 03:48 PM
woodcrest, CA
woodcrest, CA
That's good to hear that I'm on the right path
Especially because I just tore the heads off Gonna tear them down and do some bowl work, and clean up what I can. Springs aren't as bad as I thought. So I might just be able to clean as much rust off as I can and run it like that.
Just picked up a gasket set, an the pan is coming off here shortly. Gonna check out the bottom end.
Hopefully it was just head gaskets. No obvious signs of failure. Maybe not torqued enough?
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467161
07/13/13 07:25 PM
07/13/13 07:25 PM
Southern Indiana
R/T Lee Offline
R/T Lee  Offline
Southern Indiana
You said you just tore it down. How long has it been out of a car/truck? It looks like typical rust that collects on engines that have been sitting for a while. I see it all the time, I would be surprised if I didn't see any rust. I have seen those engine covers in Summit magazines, never bought one, but Im pretty sure that's why people use them, to prevent what happened to yours. I hate Murphy and his stupid laws!!
NO!! It's not a Nova...
72' Demon 340-727-8 3/4 3.55
69' Charger 440-727-8 3/4
78 Powerwagon 318-727
99' Dakota R/T 5.9
74' Scamp (project)
96' Cherokee 4.0 4x4
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: R/T Lee] #1467162
07/13/13 08:06 PM
07/13/13 08:06 PM
woodcrest, CA
woodcrest, CA
It was installed in a 59 dodge panel van, sedan delivery type truck. Supposedly sat for only 5 years.
Pulled the lifters out. The bottom and sides of the passenger last 4 were rusty too. Cam looks amazingly clean.
Haven't pulled the heads apart yet. Still waiting on a friend.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467163
07/13/13 08:16 PM
07/13/13 08:16 PM
those will clean up ez enuff with some PB Blaster & light blasting or tumbler at the machine shop.
just make sure there is no rust on the bottom of shaft where the rocker slides.
I use a straight wire brush in a die grinder to de-carbon the chambers before removing the valves,
soak valves in carb cleaner while i tape the seats up(Just learned this trick) so you dont nick them with a stone or sand/buff roll belending the cut lines and pocket porting the bowls.
might want to put a straight edge across the deck surface for a fast look to see if they need machine work that is obvious with the eye.
mag them for cracks when blown headgaskets are culprate.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: magnum440d100] #1467164
07/13/13 10:55 PM
07/13/13 10:55 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
two things to consider with rust. 1. rust on a valve spring is not good as it can become a fracture point. 2. rust inside the ports or bowls will wipe out a fresh valve job. just fyi......
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: ek3] #1467165
07/13/13 11:23 PM
07/13/13 11:23 PM
Southern Indiana
R/T Lee Offline
R/T Lee  Offline
Southern Indiana
From what you said, this is just a "temporary" motor, until your "Good one" is completed. Knowing that, I would clean up the motor the best you can, and unless the head gasket is 100% blown, I would go with it. Clean as much rust as you can, wipe everything down, and mask off any holes or ports that rust and dirt may end up when you clean it up. Some people go overboard handing out advice when its not their money or time... I'm not saying people are purposely giving bad information or advice. But over the years I've noticed some people go way over the top when giving advice. I mean come on It's a CHRYSLER, of course it will run!!!
99' Dakota R/T 5.9
74' Scamp (project)
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: R/T Lee] #1467166
07/13/13 11:40 PM
07/13/13 11:40 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
An over night soaking in some home made EvapoRust should take care of that rust.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: R/T Lee] #1467167
07/14/13 12:17 AM
07/14/13 12:17 AM
woodcrest, CA
woodcrest, CA
Yeah this is a temporary motor. Didn't get the heads finished, hopefully tomorrow.
The other 360 is still a year away, money wise. This motor has to last at LEAST a year.
Re: Rusty rocker arms, pushrods, rocker shafts... [Re: burdar] #1467168
07/14/13 12:19 AM
07/14/13 12:19 AM
woodcrest, CA
woodcrest, CA
what's the recipe?
