Trams oil #1467073
07/12/13 09:59 PM
07/12/13 09:59 PM
Iowa
beaver77 Offline OP
beaver77  Offline OP
Iowa
What oil are you guys running in your 4 speeds, I have heard some of the newer gear oil can couse problems.
Re: Trams oil [Re: beaver77] #1467074
07/12/13 11:05 PM
07/12/13 11:05 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Dextron II
I am truckless..
Re: Trams oil [Re: 340SHORTY] #1467075
07/12/13 11:08 PM
07/12/13 11:08 PM
Kirkland, Washington
Pacnorthcuda Offline
Wow... "Trams oil" and "Dextron" in the first two posts.
But besides all that, what year and tranny?
Re: Trams oil [Re: Pacnorthcuda] #1467076
07/13/13 12:07 AM
07/13/13 12:07 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Hey, I use both of those products...along with Mobile 1 oil.
It's Swifty! Swifty, you toad sucker!
Re: Trams oil [Re: 340SHORTY] #1467077
07/13/13 08:52 AM
07/13/13 08:52 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Nothing but 90 wt gear grease in my 65s 4 speed since it was new.Ive had it since 69 and no problems.Only reason that atf was used was mostly for winter driving.Rocky
Chrysler Firepower
Re: Trams oil [Re: beaver77] #1467078
07/14/13 01:00 AM
07/14/13 01:00 AM
Ma Mopar put 85/90 WT in some of the OEM 4 speeds cars and some came with ATF in them, it depended on which year, factory building the car and where the car was going to be sold from I've used both(and mixed them later) with no harmful results The early (Pre 1971) NP833 had prolems shifting smoothly, the ATF helped cure that New Procees(the tranny company)changed the syncromesh assemblys three different times over the years along with two changes on the side covers to make their trannys shift easier
Re: Trams oil [Re: Cab_Burge] #1467079
07/14/13 02:21 AM
07/14/13 02:21 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
pennzoil synchromesh is what I use.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Trams oil [Re: mopardude318] #1467080
07/14/13 03:17 PM
07/14/13 03:17 PM
Iowa
beaver77 Offline OP
beaver77  Offline OP
Iowa
Trans is a 69 833 4 speed, I dint know you could run ATF in them
Re: Trams oil [Re: beaver77] #1467081
07/14/13 07:56 PM
07/14/13 07:56 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I've run both 90 weight and ATF. Tranny shifted a little easier with ATF but was more prone to leaking.
