71 One piece throttle valve linkage(Kickdown)Re-Updated #1466852
07/12/13 01:35 PM
07/12/13 01:35 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I have my tranny mated up to the engine on a dolly and am trying to get the throttle valve linkage hooked up. I have the original one piece linkage that came off the car ('71 Satellite) but am have problems getting it to fit. First I will say that I replaced the stock intake/carb with an aluminum DP4B and 650 Eddy carb.
I have a couple of problems:
1) The linkage is ~2" to far towards the center of the engine and won't line up with the carb.
2) The one piece rod is hitting the back of the cylinder head.
Is the new intake/carb screwing me up that much? I didn't think that the new carb was 2" wider than the original. Were there two different setups (one for 2-brl and one for 4-brl)?
I'll try and post pics tonight.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466853
07/12/13 02:32 PM
07/12/13 02:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
To make the linkage work correctly you'll need the Edelbrock #1481 Mopar throttle lever extension.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466854
07/12/13 02:55 PM
07/12/13 02:55 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I wish that there were part numbers on these. I have several here that I have no use for, but I hate to throw stuff away that someone else needs. PM me if you want. I'd give you one if I have the one you need. I would probably need some pictures and measurements.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466855
07/12/13 03:10 PM
07/12/13 03:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have the adapter that john K attached ?
Also the DP4B is taller than the stock intake , how much ? maybe a 1/2" ??
But neither it or the carb would cause the linkage to hit the head , is it the same engine family as it was originally attached to ? low deck removed and replaced with a low deck ? what type of heads ?
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: JohnRR] #1466856
07/12/13 05:13 PM
07/12/13 05:13 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I do have the adapter for the Eddy carb attached. In fact adding this linkage exacerbated the problem. It makes the carb even "wider".
The engine/tranny are the original matching number pieces.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466857
07/12/13 05:15 PM
07/12/13 05:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The eddy is not any wider , did you put it on the right side of the adapter? It goes on the side toward the carb.
edit ... I'll ask the dumb question , original 4bbl car ?
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: JohnRR] #1466858
07/12/13 08:26 PM
07/12/13 08:26 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
It's originally a 2-brl car, that's why I asked earlier if it mattered between the two (2-brl/4-brl).
Here are a few pictures.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466859
07/12/13 08:29 PM
07/12/13 08:29 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Here is where you can see that I had to space the throttle linkage bracket due to the higher runners on the intake manifold. It moves it inward but only like ~1/4".
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466860
07/12/13 08:31 PM
07/12/13 08:31 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
This shows where the rod hits the head. The throttle lever on the tranny is not all the way forward yet due to hitting the head.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466861
07/12/13 08:41 PM
07/12/13 08:41 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
You need to get a 4 barrel bracket or cut/extend the one you have. This in my 440 setup. Note the distance from where the bracket is bolted on to where it rises. 383-400 ones are a little longer due to the intake being not as wide.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: T2R9] #1466862
07/12/13 09:06 PM
07/12/13 09:06 PM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
i think you can get a cable system,i believe lokar or boulichlin performance sells them.about the same money as a correct 4barrel kickdown,i have one off a 71 charger if you need one.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: T2R9] #1466863
07/12/13 11:24 PM
07/12/13 11:24 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
That's my problem, I have the 2-brl bracket. I will take this one off and extend the bracket outward by welding some extend tabs on it.
I'll post some pics of the new bracket when I get it done.
Thanks to all for the help.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466864
07/13/13 06:10 PM
07/13/13 06:10 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The link (Red arrow) between the adapter and the kickdown rod needs to be moved to where the black line (black arrow) is in the diagram. The green line and green arrow shows where the kickdown return spring is connected. You may need to lengthen the link a bit or modify the entire bracket to get it to operate correctly through the full stroke of the throttle.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466865
07/13/13 07:07 PM
07/13/13 07:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I see I was tree'd
As you have found out yo can't use 2bbl linkage on a 4bbl setup.
Also you can't space the bracket off the intake , that makes your misalignment WORSE.
Get a 4bbl throttle bracket. The flat bar may also not be the correct length for a 4 bbl .
If you decide to get a cable system get the bouchillon , the lokar is not correct for mopar .
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: JohnRR] #1466866
07/14/13 12:24 AM
07/14/13 12:24 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Well, I modified my existing bracket by adding some length to the "legs" to place it over where is needed to be.
Here is where I started.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466867
07/14/13 12:26 AM
07/14/13 12:26 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Here is where I ended up.
Not perfect, but perfectly close enough!!
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466868
07/14/13 12:27 AM
07/14/13 12:27 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Seems to line up pretty close. It's not exact but I don't think it will have any problems.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466869
07/14/13 12:27 AM
07/14/13 12:27 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
From the back.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466870
07/14/13 12:29 AM
07/14/13 12:29 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Like JohnRR said, it looks like I need to lengthen the flat bar with the slot as well.
Re: '71 One piece throttle valve linkage (Kickdown linkage) [Re: VITC_GTX] #1466871
07/14/13 12:54 AM
07/14/13 12:54 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Definitely need to lengthen the slotted connector, but it looks like you've got things under control. That is beautiful work on short notice. Someone has mad skilz.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
