71 One piece throttle valve linkage(Kickdown)Re-Updated
#1466852
07/12/13 01:35 PM
07/12/13 01:35 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
I have my tranny mated up to the engine on a dolly and am trying to get the throttle valve linkage hooked up. I have the original one piece linkage that came off the car ('71 Satellite) but am have problems getting it to fit. First I will say that I replaced the stock intake/carb with an aluminum DP4B and 650 Eddy carb.
I have a couple of problems:
1) The linkage is ~2" to far towards the center of the engine and won't line up with the carb.
2) The one piece rod is hitting the back of the cylinder head.
Is the new intake/carb screwing me up that much? I didn't think that the new carb was 2" wider than the original. Were there two different setups (one for 2-brl and one for 4-brl)?
I'll try and post pics tonight.
Re: '71 One piece throttle valve linkage (Kickdown linkage)
[Re: VITC_GTX]
#1466857
07/12/13 05:15 PM
07/12/13 05:15 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
The eddy is not any wider , did you put it on the right side of the adapter? It goes on the side toward the carb.
edit ... I'll ask the dumb question , original 4bbl car ?
[Re: VITC_GTX]
#1466870
07/14/13 12:29 AM
07/14/13 12:29 AM
VITC_GTX
Like JohnRR said, it looks like I need to lengthen the flat bar with the slot as well.
