what size axle u bolts do i need? 1985 d-150 #1466678
07/11/13 10:57 PM
07/11/13 10:57 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
I am swapping a 9 1/4 into my 1985 d-150 that currently has an 8 1/4. what size u bolts do i need? I have had zero luck with the major parts stores websites. My truck is about 100 miles away right now, so I can't measure what is on it, or measure the donor truck's u bolts either. I am swapping a 1982 small bolt pattern 9 1'4 into my 1985 large bolt pattern truck, both are 2 wd D-150's with 318's in both trucks, what id and length square u bolts do I need?
Re: what size axle u bolts do i need? 1985 d-150 [Re: tt76400] #1466679
07/11/13 11:17 PM
07/11/13 11:17 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Same size that's in it. Trucks don't have actual U shaped bolts. their squared and don't go around the axle. The spring plate is what holds the axle in place
Re: what size axle u bolts do i need? 1985 d-150 [Re: 76dodgeboy] #1466680
07/11/13 11:20 PM
07/11/13 11:20 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
When you get to your truck take one out and head to the parts store. Its practically a stock Item. Oh Ill measure some I got from RoughCountry when I get home
Re: what size axle u bolts do i need? 1985 d-150 [Re: 76dodgeboy] #1466681
07/12/13 08:42 AM
07/12/13 08:42 AM
scratchnfotraction Offline
the 8 1/4 will use the same u-bolts as the 9 1/4
they are 2.5" square end and 6" long unless it is 4x4 with blocks then they are longer.
Re: what size axle u bolts do i need? 1985 d-150 [Re: scratchnfotraction] #1466682
07/12/13 10:32 AM
07/12/13 10:32 AM
installed with the lower shock plate.
4x4 will have a 3.5" lift block so a longer u-bolt 2.5 x 12"
my local spring shop bends any size you need right there in the shop for you. last set I got for a 4x4 was 30$ for 4-12" u-bolts/8 thick washers/8 locking fine thred long nuts.
you can use one of the lowering kits with ne u-bolts from one of the autoparts stores, but most likly have to order them in.
some places are $$$$ so shop around for them if you replace them.
I have always reused mine unless they broke/rust/twist/strip before i replace them. keep a few spares around the shop too.
early 81-84 D truck rotor get you the small bolt pattern up front or a 76 new yorker front rotor will fit the bill and some times cheaper.
Re: what size axle u bolts do i need? 1985 d-150 [Re: scratchnfotraction] #1466683
07/12/13 10:55 AM
07/12/13 10:55 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Beat me to it. Tried to get pics last night but my phone died
Re: what size axle u bolts do i need? 1985 d-150 [Re: 76dodgeboy] #1466684
07/12/13 11:50 AM
07/12/13 11:50 AM
me & mine too last night.
earlybird got ya!
