Re: What is this part? Slant 6 related
[Re: 84Stepside]
#1466538
07/11/13 05:00 PM
07/11/13 05:00 PM
Paul_Fancsali
[Re: Paul_Fancsali]
#1466539
07/11/13 05:28 PM
07/11/13 05:28 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Provided you don't have inspections, the whole thing can be removed, BUT you must plug/block the hole in the head to prevent a BIG exhaust leak.
The old backyard method is to cut off the tube a few inches from where it bolts to the head and pinch it shut. You can just see the one on the van. It was done way back by someone else.
Considering those rot and are no longer available, you might want to save it and sell to someone that does have to pass inspections.
[Re: scratchnfotraction]
#1466541
07/11/13 05:55 PM
07/11/13 05:55 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I have used a freeze plug in the heads on a 360 with good results.
I tried Magnum Steel putty first... That lasted about a week...
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1466542
07/11/13 11:13 PM
07/11/13 11:13 PM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
I made a little tear drop shaped piece of 1/4" plate to cover that hole. No big deal.
[Re: 84Stepside]
#1466545
07/13/13 10:27 AM
07/13/13 10:27 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I know Ma had a factory block off plate for those. I have seen one or two on late 70's, early 80's.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
