2004 Ram 2500 4x4 - Chirping noise from front #1466104
07/10/13 08:57 PM
07/10/13 08:57 PM
Creedmoor, NC, USA
74Charger Offline OP
Creedmoor, NC, USA
My truck has developed a faint chirping noise that speeds up and slows down based on wheel rotation speed.
I checked the calipers, shims, and pads last weekend but could find nothing wrong
I rotated the front hubs with calipers removed and could feel it was a bit less than consistent as far as drag goes.
I'm wondering of the front hub bearings are worn and approaching failure. Truck has 142,000 miles.
Anyone know of any history on this symptom, and a solution or it?
Hub replacement is fairly difficult and costly from what I have heard.
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466105
07/10/13 09:14 PM
07/10/13 09:14 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Axle U-joint.
Sheldon
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: RUNCHARGER] #1466106
07/10/13 09:18 PM
07/10/13 09:18 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
Have you "been there and done that" or speculating? No insult intended.
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466107
07/10/13 10:06 PM
07/10/13 10:06 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Does it chirp more when turning? Mine was doing this and it was the axle u joint. 98 1500 ram 99,500 miles on it.
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466108
07/10/13 10:18 PM
07/10/13 10:18 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
The rear CV joint in the front drive shaft can squeak. The centering ball between the two joints and it's seal get dry. Try spraying a decent lube (not a penetrating oil) up between the joints. This was a real problem with Dakotas and 1500's thru the late 90's and early 2000's. People changed a lot of stuff they didn't need to....
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: superwrench] #1466109
07/10/13 10:56 PM
07/10/13 10:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep as I fixed that a few times working at the Dodge dealer. Ron
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466110
07/11/13 12:52 AM
07/11/13 12:52 AM
RUNCHARGER Offline
RUNCHARGER  Offline
The front axle U-joints are easy to check as well, tire off, crank the wheel to one side and wiggle the rotor back and forth while watching the u-joint. They fail lots and are easy to change.
Sheldon
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: RUNCHARGER] #1466111
07/16/13 06:10 PM
07/16/13 06:10 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
After more investigation I think the chirp is coming from the wheel hub/bearing assembly. It may be the u-joint, but there is no play there.
If I go into it, I'll be replacing the u-joint for insurance while I am there. For the cost of the u-joint, it isn't worth going back into it.
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466112
07/16/13 06:39 PM
07/16/13 06:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Let's face it, even if it's "just" the U joint you still have to pull the hub assy to pull the axle shaft, best to replace the hub and U joint if your going to tear it down, the factory hub assys are good for about a max of 150K, your just about there, whatever you do, buy the premium hub assy, don't cheap out, I did this and got about 20K on a cheap China set before I had to pull them again, busting them out the first time can be tough, a cold chisel, or impact chisel helps force them out of the knuckle, you'll need a thinwall socket, 36 MM IIRC for the front axle nut, and be sure to torque it back in place, 125 ft lbs IIRC, the hub assy is pretty simple to deal with, it's just prying them out of the knuckles that's a PITA, 2 bolts holding the caliper, 3 12 point bolts holding the hub assy from the backside of the knuckle, and of course the axle nut, put some anti-seize inside the hub bore before installing the new hub assy, and install a premium GREASE-ABLE U joint...
Mike
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: DAYCLONA] #1466113
07/18/13 10:48 PM
07/18/13 10:48 PM
Central NY
GarageDodge Online content
GarageDodge  Online Content
Central NY
175 ft lbs on the axle nut,as per chry service manual&mitchell pro demand.
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: DAYCLONA] #1466114
07/19/13 05:35 PM
07/19/13 05:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mike
what he said.
If you like the truck and want to keep it, replace both hub bearings and the u joints with quality pieces. It is not an easy job but once you get it done it will be all set for a long time.
Rich H.
Esse Quam Videri
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: ZIPPY] #1466115
07/28/13 03:36 PM
07/28/13 03:36 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
Well, i have replaced both hub bearings, both front axle u-joints,and the upper RH ball joint, and I still have this chirp that gets faster with wheel rotation.
I''m now thinking driveshaft issues......
Any ideas?
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466116
07/28/13 03:54 PM
07/28/13 03:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Any ideas?
Remove the front shaft and drive it.
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466117
07/28/13 04:19 PM
07/28/13 04:19 PM
superwrench Offline
superwrench  Offline
Any ideas?
...Like I said on here two weeks ago..... could have save ya a lot of money and aggravation
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: superwrench] #1466118
07/28/13 04:36 PM
07/28/13 04:36 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
I don't see anywhere to spray anything. Driveshaft has a boot over a "in & out" sleeve and then a double u-joint at rear. ???
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466119
07/28/13 05:20 PM
07/28/13 05:20 PM
superwrench Offline
superwrench  Offline
I'd just unbolt the whole shaft. If you look close the shaft, it "MAY" have a inverted grease fitting at the ball socket in the CV joint. I don't believe it will in those years.If you can get a small pick under the lip of the seal and squirt some sprayable grease (even white lithium spray) under the lip,in a few spots.
The noise could actually be one of the u-joints...look for a rusty residue around the cap seals at the inner part of the crosses.
All I can say is that this particular problem caused more headaches than I can count..... and as you have shown, a lot of unneccesary work. On the bright side, you now know your front end is in pretty good shape.
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: superwrench] #1466120
07/29/13 02:42 AM
07/29/13 02:42 AM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
well why not do a proper diagnosis instead of shotgunning it.[throwing parts at it].Get it in the air all 4 wheels, start it and put it in drive. Now listen for the noise.is it there? If no put it in 4wh. Is the noise there? If you here the noise try to isolate it. I use a stethoscope.a long screwdriver works good to. Put one end on the part the other up to you're ear tight and listen. Put the screw driver on the closest to the noise NON MOVING PART. Then move say 6" away. Is it louder or not? If you hear it at the trans or rear diff listen on both sides as it will travel. And narrow it down. A very abbreviated diag formula. Hope it helps.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
1970 v code superbee
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466121
07/29/13 11:47 AM
07/29/13 11:47 AM
pennsylvania
poboyengineering Offline
pennsylvania
a couple of points:
ive seen many a chirp, squeak, type sound caused by the anti rattle shims dragging on the rotor. also rust on the outer edge of the rotor hitting the caliper.
to remove the hub, I back the bolts out until there is 1/2" or so clearance to the knuckle, and use the socket with an extension to brace against the spring, axle housing, whatever is easiest, start the engine and turn the wheel. pops them right out. (this doesn't seem to work on the 1500's)
and IIRC the axle nut torque is 175#.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: superwrench] #1466122
07/31/13 12:39 PM
07/31/13 12:39 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
Your diagnosis was "dead-on" correct!
I lubed that center of the double u-joint at transfer case and no more chirping! FYI - the 2004 models have no inverted grease fitting like the 2008 and later trucks.
I'm not feling too badly about the hubs and u-joint replacements at 142,00 plus miles. I got the "best" out of them, and should be good to go for a long time now.
Also, I had to replace an upper right side ball joint that was loose, so I would have replaced hub and u-joint at the same time regardless. Now it is close to time for new tires! I wasn't doing that and front end alignment with a bad ball joint. Thanks!
Re: 2004 Ram 2500 4x4 - Chirping noise from front [Re: 74Charger] #1466123
07/31/13 04:27 PM
07/31/13 04:27 PM
superwrench Offline
superwrench  Offline
Good to hear!!! Yeh..I don't know why Chrysler didn't put a fitting on those shafts. All my old trucks from the 70's and 80's had one.
Richard
