Springs on intake valves in the ports? 1960 413 #1466054
07/10/13 07:41 PM
07/10/13 07:41 PM
Ramona, CA
NicksGarage Offline OP
Ramona, CA
A friend is working on a 1960 413 engine and it has springs on the intake valve stems inside the ports. I've never seen anything like it. Anyone know anything about these? See the picture.
Re: Springs on intake valves in the ports? 1960 413 [Re: NicksGarage] #1466055
07/10/13 10:49 PM
07/10/13 10:49 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Does it hold a seal on the bottom of the guide?
Re: Springs on intake valves in the ports? 1960 413 [Re: NicksGarage] #1466056
07/10/13 10:57 PM
07/10/13 10:57 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Looks like someone put seals in the wrong place,if anything came apart you know where it would end up !
Re: Springs on intake valves in the ports? 1960 413 [Re: NicksGarage] #1466057
07/10/13 11:24 PM
07/10/13 11:24 PM
Did that motor come from Mexico? Probally a trick of the week some time ago or a massive screw up on somebodys part originally That or one of the local other brand shops where trying to slow that big old motor down
Re: Springs on intake valves in the ports? 1960 413 [Re: Cab_Burge] #1466058
07/10/13 11:38 PM
07/10/13 11:38 PM
Ramona, CA
Ramona, CA
They say the engine looks like it has never been apart. It's out of a very rare Ghia Imperial limo. They are on every intake valve.
Re: Springs on intake valves in the ports? 1960 413 [Re: NicksGarage] #1466059
07/10/13 11:48 PM
07/10/13 11:48 PM
That car is a very rare, high dollar dude Maybe the Italians(SP?) knew something we didn't know back then
Re: Springs on intake valves in the ports? 1960 413 [Re: Cab_Burge] #1466060
07/11/13 10:27 AM
07/11/13 10:27 AM
Ramona, CA
Ramona, CA
I can't imagine Ghia would have done anything with the engine but who knows. The engines went through special handling at Chrysler. As for having those parts in there, there is not only a risk of broken parts falling into the cylinders but it can't help with airflow. I'll see if I can get some pictures of it disassembled.
Re: Springs on intake valves in the ports? 1960 413 [Re: NicksGarage] #1466061
07/11/13 10:44 AM
07/11/13 10:44 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
That spring looks too new to be 50 years old. I also doubt they had those nylon valveseals back then.
OTH, the valvestem is at least getting lubed...
Re: Springs on intake valves in the ports? 1960 413 [Re: BigBlockMopar] #1466062
07/17/13 03:07 PM
07/17/13 03:07 PM
Ramona, CA
Ramona, CA
Here is the latest update on the mystery. It appears that these are retrofit valve seals that were used on Buick Nail Head engines. Apparently Buick didn't uses valve seals on these engines until 1966 which was the last year. Some retrofit seals go on the top of the intake valve guides as normal and others are like this.
They will not be going back in when the engine is built.
Re: Springs on intake valves in the ports? 1960 413 [Re: NicksGarage] #1466063
07/17/13 05:21 PM
07/17/13 05:21 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
