Also there's no way a '58 Plymouth weighs 6000 pounds unless there's 1500+ lbs of bondo on it. It's a little wider, but not really any bigger than your Charger.
I exaggerate a bit sometimes....its a land yacht nontheless. alot more body panels on that thing to cover.
As for the balancer and its grooves...I think it has 4 grooves...one every 90 degrees. I will have to compare it to a duplicate that was accidentally sent and line the timing tape based off the crankshaft key location.
The military base here was the Naval base back in the 70s/80s...when the Americans were here in force protecting the Mediterranean when there was a Libyan conflict.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
