Lost another cam #1465744
07/10/13 01:11 AM
07/10/13 01:11 AM
Red Deer, Alberta
bill_greenwood Offline OP
Red Deer, Alberta
So...after losing a couple of lifters last year- pushrods popped through the disc on a couple of my old Comp lifters- and bending a couple pushrods, I upgraded to a set of Ferrea tool steel lifters and .145 wall chromoly pushrods. Sure enough, in spite of a diligent lifter break-in I appear to have wiped a couple of lobes. Again. The lash was still where I had set it before we went to the track, yet when relashing tonight, I discovered that one exhaust was only opening just over .400" and another was even worse.
So. It's roller time. Does anyone make a small block roller lifter that literally drops in to a non-bushed block? There are two Comp Cams grinds that would allow me to use my current springs and rockers without using up my valve-piston clearance.
Aaaaaargh!
Re: Lost another cam [Re: bill_greenwood] #1465745
07/10/13 02:04 AM
07/10/13 02:04 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Lost another cam [Re: mopardude318] #1465746
07/10/13 02:42 AM
07/10/13 02:42 AM
minnesota
royalflush Offline
royalflush  Offline
minnesota
what oil are you running?
Re: Lost another cam [Re: bill_greenwood] #1465747
07/10/13 09:22 AM
07/10/13 09:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The Comp 828 will work.. its a solid body... dont
know if you need push rod oiling
Re: Lost another cam [Re: bill_greenwood] #1465748
07/10/13 10:06 AM
07/10/13 10:06 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
when you get your new lifters in leave the intake off and prime the engine while turning over by hand. get each lifter at the tip of each cam lobe and look for oil leakage out the bottom of each lifter bore. I had that problem 8-10yrs back before Mikes MRL lifters were available. I tried cranes and comp roller lifters and they both leaked bad. I ended up with a PBM lifter made by Morel,which is a great lifter for $250 maybe $300 now. erson cams carrys them. my next set will come from MRL since I really like the bearing getting oiled directly. never an issue with the PBM's with 600# spring pressure and some street driving thou. i'm sure Mikes wont have that problem,but never hurts to check with a non bushed lifter bore. just a heads up.
Re: Lost another cam [Re: MR_P_BODY] #1465749
07/10/13 10:12 AM
07/10/13 10:12 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Mike, I believe the comp 828 is one that leaked like a sieve. the other was a crane pro $880 set. the PBM's are non pushrod oiling.
Re: Lost another cam [Re: mopar dave] #1465750
07/10/13 10:23 AM
07/10/13 10:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was running them for years in my back up W-2 engine..
always had good pressure... if you look at my lifter
post you can see them... thats at .640 lift(valve)
so if you go more you MIGHT uncover the bottom
Re: Lost another cam [Re: MR_P_BODY] #1465751
07/10/13 10:54 AM
07/10/13 10:54 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
cant remember what lift I had then,but I think it was about .650. may be more of an issue with the block. mine is a 71 360 block.
Re: Lost another cam [Re: mopar dave] #1465752
07/10/13 11:05 AM
07/10/13 11:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those oil passages are sorta random to where they
end up at since its part of the casting... mine is
a 68 or 69 340 block
Re: Lost another cam [Re: MR_P_BODY] #1465753
07/10/13 01:58 PM
07/10/13 01:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
The Comp 828's require grinding on the block. Comp 8043's have the inverted link bar and will clear.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Lost another cam [Re: Triple Threat] #1465754
07/10/13 03:11 PM
07/10/13 03:11 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
the morels/pbm required minor grinding also.
Re: Lost another cam [Re: mopar dave] #1465755
07/11/13 02:59 AM
07/11/13 02:59 AM
Red Deer, Alberta
Red Deer, Alberta
I use Pennzoil 20w50 race oil, plus applied copious amounts of cam break-in lube on lifters and lobes. If there's an upside, I have enough spring to upgrade to a mild roller, and shouldn't really need to go to a bronze dist. gear. I'm more annoyed than anything. This was supposed to be at least as low maintenance as my old 340 car, and I will be pulling the motor for the fifth time in 7 years......
Re: Lost another cam [Re: Triple Threat] #1465756
07/11/13 10:44 AM
07/11/13 10:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did very little grinding to get them to fit... I
did some grinding on the heads so I could make sure I
could get them all out with the heads on.. thats a must
for DW... just in case
Re: Lost another cam [Re: bill_greenwood] #1465757
07/11/13 03:11 PM
07/11/13 03:11 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Get rid of the Pennzoil..... I lost 2 motors from there crap... And 4 motors from Union 76's crap..
I went to Kendall and never looked back...
Just my 2 cents.
Oh and I run Castrol in all street cars....
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Lost another cam [Re: racerhog] #1465758
07/11/13 03:14 PM
07/11/13 03:14 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
20/50 brad penn and now 15/50 amsoil. good stuff
Re: Lost another cam [Re: mopar dave] #1465759
07/11/13 04:08 PM
07/11/13 04:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Kendal oil years ago now called Brad Penn. 20-50 or 10-30 to get my pressure dialed in and never lost a solid cam in 38 years. Never even removed the inner spring for breakin but if the cam was over 600 lift I would recommend that step. Matt's solid cam is on its third rebuild (7 plus years) of racing every weekend from May to the middle of November.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lost another cam [Re: bill_greenwood] #1465760
07/11/13 05:27 PM
07/11/13 05:27 PM
Az
Crizila Offline
Crizila  Offline
Az
IMO, you never solved the problem from the first cam failure. Are the lifters / lobes that failed on the same lifter bores for both failures? Look closely at the sides of the lifters that failed for vertical scratching that the other lifters don't have. You might consider burnishing the lifter bores. Excessive spring pressure, worn out lifter bores, dirt, lack of lube, improper break-in, can all be causes, but IMO, the lifers that failed weren't turning in the lifter bores - as being the most likely.
Fastest 300
Re: Lost another cam [Re: bill_greenwood] #1465761
07/11/13 06:31 PM
07/11/13 06:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
With all the cam troubles you've had why would you even thnk of not running either a bronze or phenolic distributor drive gear Same thing on the springs, to little, not enough, spring pressure kills roller liftesr When we, you and me, cut corners, Mr Murphy will kick our tails Do it correctly once BTW,sorry for your cam troubles If you race long enough you will have parts fail BTW, I would shoot for 250 lbs on the seats and at least 550 lbs opened over the nose of the cam, max lift. Best bet is to follow the cam makers recommendations on spring pressures.
Re: Lost another cam [Re: racerhog] #1465762
07/11/13 08:45 PM
07/11/13 08:45 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Just my 2 cents.
People make a big deal out of Pennzoil, I've never thought it to be anything special, and most lab tests prove it to be just a standard name brand oil.
Run VR1, Brad Penn, or Cam2 Blue Blood. The Cam2 claims to have 2100 ppm zinc and 1800 ppm phosphorous.
And I'd break the cam in with a special break-in oil.
Whats the Pennzoil racing stuff? Is that their synthetic or something?
Re: Lost another cam [Re: Crizila] #1465763
07/12/13 01:40 AM
07/12/13 01:40 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
